Lenovo g50-45 bios
Re: Lenovo g50-45 bios
>Attached Filesif you find these attachements useful please consider making a small donation to the site
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Hi!Re: Lenovo g50-45 bios
Ok,lets try a bios recovery. Format a USB flash drive as fat32 .Extract the attached file named LarneMLX64.fd from the zip folder and copy it onto the flash drive.Follow this guide from step #4 https://www.bios-mods.com/bios-recov...bios-recovery/
I know it is an old thread, but i have the same problem and maybe i'm in luck.
So... I have a Lenovo G50-45 with AMD A8-6410 CPU and Radeon R5 graphics.
The laptop is turning on, power led goes on but the screen is black. From an angle, i can see some kind of reset on the screen when i power it on, but no backlight or any info.
I can turn off the laptop with a long press, but it turns of and restarts after 25 seconds. Fan does not spin, but USB ports are powered also.
To me it seems a corrupt BIOS, i would reprogram it, but my hot air soldering station is broken and without that is kinda difficult.
I tried the bios recovery procedure described, but no joy.
I tried by pressing the keys Windows + B as in the procedure, but also with Fn + Esc what i saw on another forum.
None of these worked. I used an USB key which has a led indicator, but it did not even blink.
Would love to hear your opinion, do i have any chance to start it this way? Maybe it's not even a corrupt bios, could be a hardware failure, but voltages seem normal.
This is the motherboard type.
If you can see info on the screen using a torch/flashlight you have a backlight problem, try using HDMI. If bios is corrupt and USB recovery hasn`t worked you will have to use an SPI programmer to program it. -
Hi!
Your procedure saved this laptop, it works now!
First i want to say, that of course i checked the screen with flashlight and there was no info on it. I also checked with external monitor on both VGA and HDMI outputs.
When i said "some kind of reset", i meant that from an angle the black looked different when it was off or on.
Now, the solution. CMOS recovery worked OK, but with a catch.
On a Russian forum i saw that someone succeeded after pressing the Fn + R keys.
I tried that and bingo! Beeps, etc and in a few minutes i got my laptop working.
Thank you again, your post was a treasure.
hi..lenovo g50-45 (nm-a281 rev 1.0) bios need...mainboard has amd a6-6310 apu with r4 graphic... it also has second onboard graphic with this chip info 216-0867030....i tested few bioses that users shared with in the other posts but with them second graphic is still unknown or not working...even with drivers from lenovo for this model...sn for this laptop is PF0F0PE0......i will upload corupted bios ( old.rar)and recommended bios from lenovo with this sn (a2cn45ww.rar) ....thank you for your time and sharing.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thread merged. Type the laptop serial number.
post the contents of the bios/EC chip even if it is corrupted..
read the forum rules..https://www.badcaps.net/forum/troubl...before-postingComment
LENOVO G50-45
Model name : 80E3
Motherboard: ACULU5/ACULU6 NM-A281 REV 1.0
SN: PF06BSY2
Black screen
Please copy DMI
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by gestalt.exeHi everyone,
My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
Laptop stopped booting entirely.
I used a CH341A programmer to dump the corrupted 16MB BIOS.
i then attempted the following:- Downloaded stock BIOS BHCN39WW from Lenovo
- Trimmed it to 16MB
- Extracted the BIOS region from the corrupted dump
- Extracted the BIOS region from the stock 39WW
- Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
- Injected back my LDGB / DMI
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
