Lenovo g50-45 bios
  • Akwasi
    • Jun 2018
    • 21
    • ghana
    #41
    Re: Lenovo g50-45 bios
    Originally posted by peste
    try..
    Thanks! it worked for me one time.
    • dqtech
      Badcaps
      • Jul 2018
      • 630
      • N/A
      #42
      thanks
      • elitt
        Elit
        • May 2023
        • 3
        • tbilisi
        #43
        hi guys
        i need LENOVO G50-45 BIOS
        model name : 80E3
        the mobo is
        ACULU5/ACULU6 NM-A281
        REV 1.0
        2014-03-17
        dump A2CN25WW(V1.07)
        • antokkk1410
          • Nov 2022
          • indonesia
          #44
          thks
          • elitt
            Elit
            • May 2023
            • 3
            • tbilisi
            #45
            Hello I need dumpLENOVO G50-45 BIOS A2CN25WW (V1.07)
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #46
              Become a Badcaps supporter
              Thanks to all supporters.
              • dqtech
                Badcaps
                • Jul 2018
                • 630
                • N/A
                #47
                thanks
                • elitt
                  Elit
                  • May 2023
                  • 3
                  • tbilisi
                  #48
                  Originally posted by Vesko356
                  thanks
                  • redman13
                    • Aug 2016
                    • 66
                    • bangkok
                    #49
                    Thank ALL
                    • janos6662000
                      • Mar 2015
                      • 33
                      • Romania
                      #50
                      Ok,lets try a bios recovery. Format a USB flash drive as fat32 .Extract the attached file named LarneMLX64.fd from the zip folder and copy it onto the flash drive.Follow this guide from step #4 https://www.bios-mods.com/bios-recov...bios-recovery/
                      Hi!
                      I know it is an old thread, but i have the same problem and maybe i'm in luck.
                      So... I have a Lenovo G50-45 with AMD A8-6410 CPU and Radeon R5 graphics.
                      The laptop is turning on, power led goes on but the screen is black. From an angle, i can see some kind of reset on the screen when i power it on, but no backlight or any info.
                      I can turn off the laptop with a long press, but it turns of and restarts after 25 seconds. Fan does not spin, but USB ports are powered also.
                      To me it seems a corrupt BIOS, i would reprogram it, but my hot air soldering station is broken and without that is kinda difficult.
                      I tried the bios recovery procedure described, but no joy.
                      I tried by pressing the keys Windows + B as in the procedure, but also with Fn + Esc what i saw on another forum.
                      None of these worked. I used an USB key which has a led indicator, but it did not even blink.
                      Would love to hear your opinion, do i have any chance to start it this way? Maybe it's not even a corrupt bios, could be a hardware failure, but voltages seem normal.
                      This is the motherboard type.
Name:	2023-12-17 23-41-17.jpg
                        SMDFlea commented
                        Editing a comment
                        If you can see info on the screen using a torch/flashlight you have a backlight problem, try using HDMI. If bios is corrupt and USB recovery hasn`t worked you will have to use an SPI programmer to program it.
                      • janos6662000
                        janos6662000 commented
                        Editing a comment
                        Hi!
                        Your procedure saved this laptop, it works now!
                        First i want to say, that of course i checked the screen with flashlight and there was no info on it. I also checked with external monitor on both VGA and HDMI outputs.
                        When i said "some kind of reset", i meant that from an angle the black looked different when it was off or on.
                        Now, the solution. CMOS recovery worked OK, but with a catch.
                        On a Russian forum i saw that someone succeeded after pressing the Fn + R keys.
                        I tried that and bingo! Beeps, etc and in a few minutes i got my laptop working.
                        Thank you again, your post was a treasure.
                    • waleedkamha
                      • Jan 2023
                      • 8
                      • egypt
                      #51
                      thanks bro it's working 🧤
                      • ianbak
                        • Apr 2023
                        • 52
                        Another successful recovery with SMDFlea's BIOS file and the Function + R trick! Thanks guys!
                        • soso technician
                          • Nov 2019
                          • 64
                          • iran
                          #53
                          hi..lenovo g50-45 (nm-a281 rev 1.0) bios need...mainboard has amd a6-6310 apu with r4 graphic... it also has second onboard graphic with this chip info 216-0867030....i tested few bioses that users shared with in the other posts but with them second graphic is still unknown or not working...even with drivers from lenovo for this model...sn for this laptop is PF0F0PE0......i will upload corupted bios ( old.rar)and recommended bios from lenovo with this sn (a2cn45ww.rar) ....thank you for your time and sharing.
                            SMDFlea commented
                            Editing a comment
                            Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
                        • Debil
                          • Sep 2024
                          • Hui
                          #54
                          Try this one.
                          Thank you!
                          • amirarbabi
                            • Feb 2019
                            • 34
                            • usa
                            #55
                            try..
                            thankyoy
                            • cüneyt
                              payla?mak güzel
                              • Aug 2021
                              • 4
                              • Türkiye
                              #56
                              Hello friends, I need LENOVO G50-45 ACULU5/ACULU6 NM-A281 REV 1.0 ec bios please help
                                • 21037
                                Thread merged. Type the laptop serial number.
                                post the contents of the bios/EC chip even if it is corrupted..
                                read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                                • lucaszmn
                                  by lucaszmn
                                  Problem:
                                  Initial Findings:
                                  • I concluded that the
                                  08-12-2025, 03:01 PM
                                • Wahaz
                                  by Wahaz
                                  10-30-2023, 08:42 PM
                                • grimacelord
                                  Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                  by grimacelord
                                  Hello there.
                                  I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                  History:
                                  1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                  I searched for this error online and discovered...
                                  03-15-2023, 03:29 PM
                                • jendkkd jeje
                                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                  by jendkkd jeje
                                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                  10-11-2024, 03:12 PM
                                • 1g0r
                                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                  by 1g0r
                                  First, the data in brief:
                                  Manufacturer: Lenovo
                                  Model: ThinkPad L15 G3 21C3-0016GE
                                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                  IC Bios 1: MX77L25650F
                                  IC Bios 2​: MX25L25673G
                                  EC Chip: NPCX997KAABX
                                  So far I've been a silent reader, but now I need your help
                                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                  01-18-2025, 02:39 AM
