Need bios dump for Elitebook 850 G3
  • BishopCaps
    • Jun 2021
    • 23
    • United Kingdom
    #61
    Re: Need bios dump for Elitebook 850 G3
    Hi thanks for reply.
    Below from an identical laptop.
    can you please clean so it can be used on this other?
    • peste
      • Dec 2016
      • 13739
      • ROMANIA
      #62
      try..
      • BishopCaps
        • Jun 2021
        • 23
        • United Kingdom
        #63
        Thanks,
        Programmed and resoldered - Power on, Blinking caps and num.
        Then, power off and fan spins max power on no display.
        • BishopCaps
          • Jun 2021
          • 23
          • United Kingdom
          #64
          Originally posted by peste
          try..
          Any help?
          • BishopCaps
            • Jun 2021
            • 23
            • United Kingdom
            #65
            HP Elitebook 850 G3
            Hello all
            Thanks for reading.
            Ill start by saying this is a new hobby of mine and I am using a CH341A programmer.
            I have reprogrammed 4 of thesw WSON8 W25q128fv chips with success but am struggling with my 5th.
            Motherboard: 6050a2892401-mb-a01 bios
            Chip was dead and unreadable,(from me trying to make a clip for it) so downloaded a bios for the above, programmed and resoldered.
            Getting full fan and power light on no display.
            I have tried other dumps from my laptops of the same model, they get a BIOS error signal on caps and num keys.
            If you're still reading, I need a BIOS dump for this motherboard, and any assistance / advise for a novice if possible
            much appreciated
            Anthony
            • aboumohamed
              • Dec 2018
              • 258
              • algeria
              #66
              Re: HP Elitebook 850 G3
              try this dump
              • aboumohamed
                • Dec 2018
                • 258
                • algeria
                #67
                2nd dump
                • BishopCaps
                  • Jun 2021
                  • 23
                  • United Kingdom
                  #68
                  Originally posted by aboumohamed
                  try this dump
                  Thank you - programming now
                  • BishopCaps
                    • Jun 2021
                    • 23
                    • United Kingdom
                    #69
                    try this dump
                    Same thing. Max fan. Powerlights on.
                    I have verified the program.
                      • 22097
                      Find an 850 G3 bios with clean ME firmware, use the forum search you`ll find one.If it still doesn`t boot then the problem is somewhere else.
                      • chestercc
                        • Jul 2017
                        • 11
                        • United Kingdom
                        #71
                        Can someone unlock this 850 G3 bios dump - i've tried the hp unlocker which produces an unlocked file but the power on password is still there after reflashing and refitting the chip.
                          • 22097
                          Open the bios with a hex editor, fill the area selected between the offsets in the picture with zeros.Then use the RCUnlocker
                          HxD hex editor https://mh-nexus.de/en/hxd/
                          • chestercc
                            • Jul 2017
                            • 11
                            • United Kingdom
                            #73
                            worked a charm thank you!
                            • Genova
                              • Jan 2020
                              • 118
                              • FRANCE
                              #74
                              850 G3 bios
                              Hi guys,
                              Hope you are all goods
                              i need a clean me bios for HP 850 G3.
                              Board CT : PFKZU00WBB760M1
                              anyone have this?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12415
                                #75
                                Re: 850 G3 bios
                                Where's your original corrupt bios file ?
                                • Genova
                                  • Jan 2020
                                  • 118
                                  • FRANCE
                                  #76
                                  Re: 850 G3 bios
                                  I didn't think it was necessary, here it is
                                  bios error is : (A7) me fw downgrade - request mespilock failed
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12415
                                    #77
                                    Re: 850 G3 bios
                                    HP EliteBook 850 G3 Notebook PC
                                    Serial number : 5CG7181BWR
                                    • Genova
                                      • Jan 2020
                                      • 118
                                      • FRANCE
                                      #78
                                      Re: 850 G3 bios
                                      Thanks will try asap
                                      • Genova
                                        • Jan 2020
                                        • 118
                                        • FRANCE
                                        #79
                                        Re: 850 G3 bios
                                        Perfectly works merci !
                                        • Genova
                                          • Jan 2020
                                          • 118
                                          • FRANCE
                                          #80
                                          Hi guys,
                                          Another one with same problem : (A7) me fw downgrade....
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
