Need bios dump for Elitebook 850 G3
  • BishopCaps
    • Jun 2021
    • 23
    • United Kingdom
    #61
    Re: Need bios dump for Elitebook 850 G3
    Hi thanks for reply.
    Below from an identical laptop.
    can you please clean so it can be used on this other?
    • peste
      • Dec 2016
      • 12859
      • ROMANIA
      #62
      try..
      • BishopCaps
        • Jun 2021
        • 23
        • United Kingdom
        #63
        Thanks,
        Programmed and resoldered - Power on, Blinking caps and num.
        Then, power off and fan spins max power on no display.
        • BishopCaps
          • Jun 2021
          • 23
          • United Kingdom
          #64
          Originally posted by peste
          try..
          Any help?
          • BishopCaps
            • Jun 2021
            • 23
            • United Kingdom
            #65
            HP Elitebook 850 G3
            Hello all
            Thanks for reading.
            Ill start by saying this is a new hobby of mine and I am using a CH341A programmer.
            I have reprogrammed 4 of thesw WSON8 W25q128fv chips with success but am struggling with my 5th.
            Motherboard: 6050a2892401-mb-a01 bios
            Chip was dead and unreadable,(from me trying to make a clip for it) so downloaded a bios for the above, programmed and resoldered.
            Getting full fan and power light on no display.
            I have tried other dumps from my laptops of the same model, they get a BIOS error signal on caps and num keys.
            If you're still reading, I need a BIOS dump for this motherboard, and any assistance / advise for a novice if possible
            much appreciated
            Anthony
            • aboumohamed
              • Dec 2018
              • 258
              • algeria
              #66
              Re: HP Elitebook 850 G3
              try this dump
              • aboumohamed
                • Dec 2018
                • 258
                • algeria
                #67
                2nd dump
                • BishopCaps
                  • Jun 2021
                  • 23
                  • United Kingdom
                  #68
                  Originally posted by aboumohamed
                  try this dump
                  Thank you - programming now
                  • BishopCaps
                    • Jun 2021
                    • 23
                    • United Kingdom
                    #69
                    try this dump
                    Same thing. Max fan. Powerlights on.
                    I have verified the program.
                      • 20977
                      Find an 850 G3 bios with clean ME firmware, use the forum search you`ll find one.If it still doesn`t boot then the problem is somewhere else.
                      • chestercc
                        • Jul 2017
                        • 11
                        • United Kingdom
                        #71
                        Can someone unlock this 850 G3 bios dump - i've tried the hp unlocker which produces an unlocked file but the power on password is still there after reflashing and refitting the chip.
                          • 20977
                          Open the bios with a hex editor, fill the area selected between the offsets in the picture with zeros.Then use the RCUnlocker
                          HxD hex editor https://mh-nexus.de/en/hxd/
                          • chestercc
                            • Jul 2017
                            • 11
                            • United Kingdom
                            #73
                            worked a charm thank you!
                            • Genova
                              • Jan 2020
                              • 116
                              • FRANCE
                              #74
                              850 G3 bios
                              Hi guys,
                              Hope you are all goods
                              i need a clean me bios for HP 850 G3.
                              Board CT : PFKZU00WBB760M1
                              anyone have this?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11794
                                #75
                                Re: 850 G3 bios
                                Where's your original corrupt bios file ?
                                • Genova
                                  • Jan 2020
                                  • 116
                                  • FRANCE
                                  #76
                                  Re: 850 G3 bios
                                  I didn't think it was necessary, here it is
                                  bios error is : (A7) me fw downgrade - request mespilock failed
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11794
                                    #77
                                    Re: 850 G3 bios
                                    HP EliteBook 850 G3 Notebook PC
                                    Serial number : 5CG7181BWR
                                    • Genova
                                      • Jan 2020
                                      • 116
                                      • FRANCE
                                      #78
                                      Re: 850 G3 bios
                                      Thanks will try asap
                                      • Genova
                                        • Jan 2020
                                        • 116
                                        • FRANCE
                                        #79
                                        Re: 850 G3 bios
                                        Perfectly works merci !
                                        • Genova
                                          • Jan 2020
                                          • 116
                                          • FRANCE
                                          #80
                                          Hi guys,
                                          Another one with same problem : (A7) me fw downgrade....
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • mediadoctor
                                            Need bios dump HP EliteBook G845 G8 with AMD and Touchscreen support
                                            by mediadoctor
                                            Can you help me upload Bios dump from HP EliteBook 845 G8 with AMD CPU and Touchscreen please 🤝
                                            07-20-2025, 09:38 AM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
