Dell 5559 bios
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: Dell 5559 bios
can someone help me to erase password? EA78Attached FilesComment
Re: Dell 5559 bios
E7A8 suffix:
Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Re: Dell 5559 bios
i try all files no one working with i 5 -with ati vga
this ont work good tested 100%Comment
Device: Laptop
Brand: Dell
Model: Inspiron 5559 P51F004
Service Tag:HPTYBG2
Board number: aal15 la-d071p rev 1.0 (a00)
Original bios is attached, password is being requested on startup. Many thanks!!!Comment
DONT USE EXTARNAL SITE TO UPLOAD YOUR BACKUP FILE
POST ONLY ON BADCAPS​
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Name your thread with model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
hi everyone
so I have BIOS problem with Dell Inspiron 5559 with Service Tag: JC0M462.
"board Info: AAL15 LA-D071P Rev : 1.0(A00) 2015-07-06"
I have to add I replace the BIOS IC with new one, Because the old one can't read from or write to.
because of that I can't Read the old File.
IC name it's "winbond 25Q128FV" .
I already try all BIN file provided here so in general I facing 3 result:
1-machin turn on ,no screen , fan working full speed .
2- it's turn on ,no screen , slow fan speed ,but then after a few sec it's turn off itself.
3-totaly NO respond and do not do anything.
thank you all.
Try this file ......hi everyone
thank you all.Attached FilesComment
​https://www.badcaps.net/donateComment
Try this ..
F782K72-6FF1 Password is: oxzoVmttoEsEVRrm
or
F782K72-BF97 Password is: N2sppjNZE[kXcsNZ
The password was generated for a US keyboard and it is very important to write it that way.​
If the keyboard type on your notebook is German ( QWERTZ ) or French ( AZERTY ), connect a USB keyboard with QWERTY type
Enter the password slowly. Pay attention to big and small letters.
After entering your password, press the left Ctrl key and continue holding it, press Enter twiceComment
DELL INSPIRON 5559.
BOARD AAL15 LA-D071P REV 1.0 (00).
SERVICE TAG. 84SW652.
WITH AMD GRAPHICS.
BIOS IC MXIC MX25L12873F. ​Attached FilesComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
