Dell 5559 bios
Re: Dell 5559 bios
I need a bios for Dell 5559 . it is UMA version , attached original dump file . tried many bios on here they all give black screenAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dell 5559 bios
Here's your Clean file, try it.Attached Filesif you find these attachements useful please consider making a small donation to the site
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Re: Dell 5559 bios
Need bios repair Inspiron 5559
Service Tag: DXCLBG2
board code AAL15 LA-D071P REV 1.0
First display comes late and hangs or blue screen after 15 mints
old bios attachedAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dell 5559 bios
I tries to update bios from dell official site, but my laptop batery id dead, so i failed to update it.
Any solution to update it through usb or somebody can clean my bios???Comment
Re: Dell 5559 bios
Try your own file me clean ....Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dell 5559 bios
Learning and experience,there is no simple way https://winraid.level1techs.com/t/gu...lization/31277Comment
Re: Dell 5559 bios
LA-D071P with vgaAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dell 5559 bios
Hello, can someone clear ME of this bios dump?Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dell 5559 bios
Here's your Clean BIOS, try it.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dell 5559 bios
no display in this bios , make it ok with clearme, thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
