Need DUMP Lenovo G700 SJTNV IT8528E.rar
  • kimrocco
    • Jan 2014
    • 56
    • F2
    hey friends
    Bios ,kbc ite8528e dump needed
    http://www.chinafix.com/thread-831727-1-1.html
    thanks
  • khaahk
    • Dec 2013
    • 776
    • Estonia
    Re: Need DUMP Lenovo G700 SJTNV IT8528E.rar
    • kimrocco
      • Jan 2014
      • 56
      • F2
      thank you brother
      I need DUMP (KBC I/O IT8528E.rar)
      • khaahk
        • Dec 2013
        • 776
        • Estonia
        I think it is inside PCH file and the ite gets programmed each time machine gets stby power.
        • kimrocco
          • Jan 2014
          • 56
          • F2
          thank you brother
          problem is Password BIOS
          • khaahk
            • Dec 2013
            • 776
            • Estonia
            Did it solve the problem?
            • kimrocco
              • Jan 2014
              • 56
              • F2
              not yet brother
              There is three problems now for this case. No one has been solved.
              1- I need to have the KBC BIOS which I don t have.
              2- I need to have the good programmer that can flash the firmeware on the KBC.
              3- I need to know which pins should I connect the SIO, to be able to communicate with the KBC BIOS inside the SIO.
              It seems that there is still no programmer that is able to flash the ITE8525E SIO chip.
              • khaahk
                • Dec 2013
                • 776
                • Estonia
                Did you try the provided dump?
                There is a good chance that the ITE is reprogrammed from the pch flash rom by mainboard and there is no need to program it manually.
                There are ITE82xx programmers, but in this case i think it is not needed.
                • kimrocco
                  • Jan 2014
                  • 56
                  • F2
                  Yes , thank you
                  • toufik sat
                    • Feb 2016
                    • 134
                    • los angles
                    Yes , thank you
                    • Pascal Komlassan
                      • Jan 2017
                      • 809
                      • TOGO
                      Originally posted by khaahk
                      thanks bro
                      • englez
                        • Jul 2012
                        • 30
                        • Serbia
                        Thank you
                        • AHmad_Salal
                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                          by AHmad_Salal
                          Hello all,
                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                          11-28-2023, 05:28 AM
                        • mrkmpn
                          Lenovo X1 Carbon 7th Gen Type 20R1 BIOS DUMP
                          by mrkmpn
                          SN: PF1Y5BBJ
                          Board: GX490 NM-C661 Rev: 1.0
                          I have made two dumps of this bios, with the bios chip removed from the board and the hashes match on both dumps, but I cannot find the DMI information in the dumps except for the Windows product key, so I think it is corrupted. I have downloaded two bios updates from the Lenovo support site, but they contain small .PAT file, and 4 subfolders containing .FL1 and .FL2 files, which I don't understand enough to figure out how to use to fix my dump.
                          The problem with the laptop is that...
                          05-21-2024, 09:14 AM
                        • bob113313
                          extract bios dump file from exe Lenovo amd ideapad 5 15alc05
                          by bob113313
                          first of all my apologies for my English (I don't speak it very well, I am French).
                          I am trying to troubleshoot a lenovo ideapad 5 15alc05 ryzen 7 that boots but remains in black screen.
                          I would like to know if anyone knows how to extract the .bin of bios from the exe published on the lenovo site. I have found several information on the internet but they don't work in my case. I think it's because it's an amd.
                          I found some dump on the internet but I don't really trust it. I would like to make a clean bis from the official Lenovo file...
                          12-10-2022, 05:16 AM
                        • hirens
                          Lenovo ideapad 3 14IGL05 bios dump needed
                          by hirens
                          model: 81wh
                          sn: pf36ta6h
                          board no: nm-c961 gs453/gs553
                          hey guys above is my laptop info
                          it only blinks the power button kindly help me with a working dump
                          old dump attached...
                          07-21-2023, 04:48 AM
                        • ilias7790
                          Need Lenovo T14s Gen1 type AMD-EC IT and bios dump
                          by ilias7790
                          06-14-2024, 05:44 AM
