Need DUMP Lenovo G700 SJTNV IT8528E.rar
  • kimrocco
    • Jan 2014
    • 56
    • F2
    hey friends
    Bios ,kbc ite8528e dump needed
    http://www.chinafix.com/thread-831727-1-1.html
    thanks
  • khaahk
    • Dec 2013
    • 775
    • Estonia
    Re: Need DUMP Lenovo G700 SJTNV IT8528E.rar
    • kimrocco
      • Jan 2014
      • 56
      • F2
      thank you brother
      I need DUMP (KBC I/O IT8528E.rar)
      • khaahk
        • Dec 2013
        • 775
        • Estonia
        I think it is inside PCH file and the ite gets programmed each time machine gets stby power.
        • kimrocco
          • Jan 2014
          • 56
          • F2
          thank you brother
          problem is Password BIOS
          • khaahk
            • Dec 2013
            • 775
            • Estonia
            Did it solve the problem?
            • kimrocco
              • Jan 2014
              • 56
              • F2
              not yet brother
              There is three problems now for this case. No one has been solved.
              1- I need to have the KBC BIOS which I don t have.
              2- I need to have the good programmer that can flash the firmeware on the KBC.
              3- I need to know which pins should I connect the SIO, to be able to communicate with the KBC BIOS inside the SIO.
              It seems that there is still no programmer that is able to flash the ITE8525E SIO chip.
              • khaahk
                • Dec 2013
                • 775
                • Estonia
                Did you try the provided dump?
                There is a good chance that the ITE is reprogrammed from the pch flash rom by mainboard and there is no need to program it manually.
                There are ITE82xx programmers, but in this case i think it is not needed.
                • kimrocco
                  • Jan 2014
                  • 56
                  • F2
                  Yes , thank you
                  • toufik sat
                    • Feb 2016
                    • 134
                    • los angles
                    Yes , thank you
                    • Pascal Komlassan
                      • Jan 2017
                      • 809
                      • TOGO
                      Originally posted by khaahk
                      thanks bro
                      • englez
                        • Jul 2012
                        • 30
                        • Serbia
                        Thank you
                        • hyperwood
                          [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                          by hyperwood
                          I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                          The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                          I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                          āœ… What I need:
                          • A working 2MB BIOS dump
                          • Matching NM-E471 Rev. 2.0, e.g. JY575
                          06-25-2025, 02:28 PM
                        • AHmad_Salal
                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                          by AHmad_Salal
                          Hello all,
                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                          11-28-2023, 05:28 AM
                        • mrkmpn
                          Lenovo X1 Carbon 7th Gen Type 20R1 BIOS DUMP
                          by mrkmpn
                          SN: PF1Y5BBJ
                          Board: GX490 NM-C661 Rev: 1.0
                          I have made two dumps of this bios, with the bios chip removed from the board and the hashes match on both dumps, but I cannot find the DMI information in the dumps except for the Windows product key, so I think it is corrupted. I have downloaded two bios updates from the Lenovo support site, but they contain small .PAT file, and 4 subfolders containing .FL1 and .FL2 files, which I don't understand enough to figure out how to use to fix my dump.
                          The problem with the laptop is that...
                          05-21-2024, 09:14 AM
                        • Captaincrap420
                          Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
                          by Captaincrap420
                          Hi, I hope this is the right place to post this. This is my first post on this forum.
                          A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
                          This bios dump is straight from the chip, nothing has been...
                          11-29-2024, 05:40 PM
                        • Antimatt3r88
                          Bios Dump Request - Lenovo IdeaCentre AIO 3 27IRH9
                          by Antimatt3r88
                          Hello guys,
                          Can a kind soul please help me with a dump file for:
                          Lenovo IdeaCentre AIO 3 27IRH9 Type F0HM
                          SN: MP2B7K7A
                          Thanks in advance!...
                          07-25-2025, 10:25 AM
