Lenovo X1 Carbon 7th Gen Type 20R1 BIOS DUMP
  • mrkmpn
    • Apr 2022
    • 62
    SN: PF1Y5BBJ
    Board: GX490 NM-C661 Rev: 1.0
    I have made two dumps of this bios, with the bios chip removed from the board and the hashes match on both dumps, but I cannot find the DMI information in the dumps except for the Windows product key, so I think it is corrupted. I have downloaded two bios updates from the Lenovo support site, but they contain small .PAT file, and 4 subfolders containing .FL1 and .FL2 files, which I don't understand enough to figure out how to use to fix my dump.
    The problem with the laptop is that it will not power on. USB-C meter shows 20v is negotiated, but does not show charging current if battery is connected, and nothing happens when power button is pressed. Any help is greatly appreciated.
    Here is my dump.
    • 21986
    Only the win key is in the bios,the DMI is in the EC. Seems to me like you`ve got a hardware problem rather than the bios
    • mrkmpn
      • Apr 2022
      • 62
      Okay, thank you.,
      • Zarithya
        • Oct 2025
        • 11
        Hi all, I have a Lenovo ThinkPad X1 Carbon Gen 7 type 20R1, motherboard model NM-C661 (which is why I believe this is the right thread despite being a Carbon).
        The laptop lost power in the middle of a BIOS update and was (presumably) corrupted. Now it does not turn on at all (no display, no fan), with three flashes of the power LED along with an amber charging LED when plugged in.
        Model: Lenovo ThinkPad X1 Carbon Gen 7
        Type: 20R1-S05A00
        Serial: PF-21E8NG
        Motherboard: NM-C661
        I've attached the dump I was able to take. I was unable to figure out how to extract a flashable file from Lenovo's download, so any help is appreciated.
          SMDFlea commented
          Editing a comment
          post moved to carbon 20R1 topic.
      • m1ch43lzm
        • Mar 2019
        • 969
        • Peru
        Try, BIOS region + EC + clean ME
        X1 Carbon 7th Gen - (Type 20R1, 20R2) Laptop (ThinkPad) - Type 20R1
        BIOS ver. N2QET56W
        ME 14.1.67.2046
        Win key 12C0000-12CFFFF
        If BIOS doesn't work please say so, maybe someone else knows how to merge ThinkPad BIOS properly, for type 20R1 the BIOS version should be N2QET**W or N2QET**P
        • Zarithya
          • Oct 2025
          • 11
          BIOS ver. N2QET56W
          ME 14.1.67.2046
          Thanks, unfortunately this did not change the behavior. Really starting to suspect the EC now...
          • reformatt
            • Feb 2020
            • 1522
            Try this one. Original BIOS region (which I believe is fine from your original dump), clean ME from same motherboard (CSME is 0x7D4000 in this donor compared to your old one) . Problem is there are no working dumps for this 20R1 that I could find for FIT configuration. Your dump has an error when loaded into FIT so cannot get the config loaded properly.
            • Zarithya
              • Oct 2025
              • 11
              No dice, unfortunately. Same three blinks on the power button.
              • LBTT1121
                • Nov 2024
                • 1069
                • Việt Nam
                try
                • AHmad_Salal
                  Need BIOS Dump/ROM for Lenovo Thinkstation p500
                  by AHmad_Salal
                  Hello all,
                  I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                  11-28-2023, 05:28 AM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • hyperwood
                  [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                  by hyperwood
                  I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                  The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                  I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                  ✅ What I need:
                  • A working 2MB BIOS dump
                  • Matching NM-E471 Rev. 2.0, e.g. JY575
                  06-25-2025, 02:28 PM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
