HP Elitebook 820 G2 bios needed
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    #141
    Re: HP Elitebook 820 G2 bios needed
    Originally posted by Chuck_Norris_2552
    Hello imranromi,
    can you or somebody else remove the bios password of my elitebook 820 g2.
    I have tried so many things and they all didnt work.
    Just say what you need to do it. (Sorry I am a noob)
    Thanks.
    Where is your bios file post here.
    • Chuck_Norris_2552
      • Jul 2018
      Here is the file.
      I hope it's the right one
      Did it with Bios Backup toolkit
      Hope you can start something with it
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        #143
        Here is the file.
        Not right use bios programmer if have read and save other no have solution.
        • vince59
          • Nov 2017
          • 46
          • italy
          #144
          Hi all. I am one of the peson that has been helped by Imranromi and would like to thank him.
          By the way I would like to know what is the process of having the BIOS file cleaned up. Another member wrote me this...
          "Ok real easy take your top half of your original file and merge it with the bottom half of either the update or donor file so let's say your bio's file is 8mb so the first 4mb merge to the other 4mb and you are done on most hp on newer ones pass words are stored in the kbc all doable just need the correct programmer to load the clean firmware and the last is the newer hex tool using disable code .
          Techman1025"
          ... is that true?
          • vince59
            • Nov 2017
            • 46
            • italy
            #145
            I also noticed that while file(bios dump) read from the chip is 16MB the update file downloaded from HP support area is 9 MB.
            I do not understand the difference here.
            Anybody can help?
            • Sojke
              • Apr 2017
              • 131
              • Serbia
              #146
              Take working BIOS + Clear ME -> Machine is not in committed state
              Try HP Brand13 -> ME has been committed it can not be committed again Failed to commit Status = 80000000000007
              How to fix????
              • attmartin
                • Apr 2016
                • Brno
                #147
                Hi friends, can you help me with clear bios pass on HP 820 G2? Thank you very much!
                • celebris3
                  • Dec 2017
                  #148
                  Thank you, but isn't working video any longer.
                  • bachir2004
                    • Feb 2015
                    • 439
                    • maroc
                    #149
                    How to fix????
                    have you solved your problem.i have the same return error on a probook 450 G2 even with an unlocked mpm.
                      • 22159
                      Imranromi had the same problem as you,fixed by manually editing the DMI info . https://www.badcaps.net/forum/showth...t=52848&page=9
                      • bachir2004
                        • Feb 2015
                        • 439
                        • maroc
                        #151
                        SMDFlea,thanks for your answer,but i did before on another unit with success but this keeps returning the same message whatever i do."ME has been committed it can not be committed again Failed to commit Status = 80000000000007".this with uncommited state and mpm unlocked.
                        • miguekun
                          • Mar 2014
                          • 5
                          • spain
                          #152
                          Can I ask for an unlock?
                          thanks in advance
                          • techman1025
                            • Jun 2014
                            • 497
                            In most cases you need to pull the chip they sell a clip so no need to pull chip off but I never had to much luck with it. Need a programmer like the t860 A around 100. On eBay with the correct adapters read chip save a copy the upload in you case I think you model has to chips main bios &EC . So what’s the problem . Password.
                            Techman1025
                            • vince59
                              • Nov 2017
                              • 46
                              • italy
                              #154
                              I have a tech question about BIOS manipulating. IAW the information I had from the forum it is quite easy to remove the password just merging the first half of the dump file with the second half of update/donor file. Fact is that I have a dump file that is 16 MB large and the original bin file from HP (let us say the N75 013 BIOS) that is a bin file 9 MB large.
                              That said, If I take half of dump file I'll have 8 MB, if I then take half of original BIOS I'll have 4,5 MB....so the total will be more or less - 12,5 MB - smaller than 16 MB but I see that the modified files are always 16 MB.
                              Is my understanding right or not?
                              Thank you for your help.
                              • ala_borbe
                                aka Donald
                                • 1625
                                • Malta
                                #155
                                The file you downloaded from web (9 mb file) does not go on start of 16mb file, it goes to the end. Open 9 mb file in hex editor and scroll untill you find bytes that are not 0x00h... open 16mb file also and search first few bytes from 9mb file and then overrite 16mb file with 9mb file. It must fit, it must not be bigger or smaller than 16mb qnd thats it
                                Im Back... sort of...
                                • vince59
                                  • Nov 2017
                                  • 46
                                  • italy
                                  #156
                                  Thank you for your kind and clear answer. I will try.
                                  Time ago I contacted HP for support and I received the smc.bin file from HP but the proceure did not work.
                                  I can provide the file to forum members for studying purposes if someone is interested.
                                  • sapkad
                                    • Feb 2019
                                    • 6
                                    • Lietuva
                                    #157
                                    hi need 820 g2 no admin password
                                    thanx
                                    • Simon16
                                      • Sep 2017
                                      • 102
                                      • España
                                      #158
                                      Hi, can you please clean the password bios?
                                      I attach my current file
                                      Thanks in advance
                                      • luisbrank
                                        • Oct 2017
                                        • 21
                                        • morocco
                                        #159
                                        hey all can any one help for unclock theis dump
                                        for hp elitebook 820 g2
                                        thx for all
                                        • timclb
                                          • Apr 2019
                                          • usa
                                          #160
                                          Thanks for the help. When i tried to write this file i got the following error "chip main memory with the contents are in disagreement" Screenshot is attached. Is it the file or am i doing something wrong?
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • TacticalFahrrad
                                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                            by TacticalFahrrad
                                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                            06-30-2025, 04:09 AM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • James Maxwell
                                            HP DM1-4000er Bios Dump needed
                                            by James Maxwell
                                            I badly need bios dump for HP DM1-4000er,
                                            Model: HP DM1-4000er
                                            Motherboard: DA0NM9MB6D0 REV.D
                                            Product: QJ490EA#ACB
                                            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                            10-28-2024, 05:38 PM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
