HP Elitebook 820 G2 bios needed
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    #61
    Re: HP Elitebook 820 G2 bios needed
    Originally posted by ardeyalex
    I tried this dump too, still 20 second until post image
    Normally, to remove the bios password , I reprogram the EC and the main BIOS with a dump taken from the same machine.
    This solves the problem of '' uncommitted state " but remains the delay of 20 seconds before it Appears the hp logo.
    What is the solution of this problem?
    thank you
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      #62
      i do not know if this thread makes me MAD or SAD
      cant you use fucking google
      solution
      HP – Warning Machine is not in committed state
      http://www.compit.se/?p=206
      Im Back... sort of...
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        #63
        solution
        I haven't this problem "committed state .." , machine work well without errors, only delay at start up. I've used wndmifit and other tools without success, all the serial numbers are correct etc.
        What does do a google search? I probably already done.
        I just wanted to know what checks the bios during startup that causing the delay.
        This problem is very common even on machines with EC and original bios that they have never had any problems.
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          #64
          Is your PCID correct? if you use bios that was original on that pc then me is not problem
          if its fro m another pc, then maybe its me region
          must enter all data in nbdmifit not only ones you see in bios it will stop doing that
          • jasko_jacker
            • Oct 2014
            • 1140
            • italy
            #65
            Unfortunately, both originals bios and me have been lost.
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              #66
              if you want to test and experiment a bit send me those working dumps
              (the one that works with delay on pm or here)
              • jasko_jacker
                • Oct 2014
                • 1140
                • italy
                #67
                I tried to update ME region but using UEFITool_0.3.0 not appear the "descriptor" and I can not continue ..
                This is the EC and the BIOS dump.
                But the PCID is stored in other parts as well as in EC ?
                thanks
                • rioreno
                  • Feb 2009
                  • 540
                  • Indonesia
                  #68
                  thanks
                  try this...
                  use both file, after that you can update from website..
                  goodluck
                  • jasko_jacker
                    • Oct 2014
                    • 1140
                    • italy
                    #69
                    Originally posted by rioreno
                    try this...
                    goodluck
                    Ok, thanks, I'm starting to reprogram the two chips.
                    I notice that in your main bios ME region is present and in EC file some data as SKU, serial , PCID, etc has changed.
                    You know a tool to change data in EC memory directly with software ?
                    this chip is placed in a bad position to use clamp and must be desoldered.
                    I tried RWeverything with no luck
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      #70
                      To change DMI data( CSN,SKU,MODEL,UUID,etc)
                      1. For file bios bin only using hexeditor... and off course lots of patient...
                      2. To change from directly using windows HP BCUtility (32/64bit)..try google how to using... clue : you playing TXT ,,,read,edit,write
                      Good luck
                      • jasko_jacker
                        • Oct 2014
                        • 1140
                        • italy
                        #71
                        Good luck
                        The delay remain the same and the bios is for 850 not for 840
                        Unfortunately, this information is in the EC separate memory from the main bios, I'm searching a tool to reprogram this chip without having to unsolder.
                        but I solved it by soldering wires between the chip and the programmer.
                        The problem remains if you want to experiment
                        • rioreno
                          • Feb 2009
                          • 540
                          • Indonesia
                          #72
                          You mean 'tool' , are soic clip?
                          • jasko_jacker
                            • Oct 2014
                            • 1140
                            • italy
                            #73
                            software tool as RWEverything but with the possibility to write on the EC memory chip. Probably, if it is possible, in linux there is something like ftpw64 (dos for main bios)
                            • rioreno
                              • Feb 2009
                              • 540
                              • Indonesia
                              #74
                              which i know are only HPBCUtiilty...wndmifit not completed only serial number and cannot uuid please you try first hpbcu...give me hbcutility txt read output..
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                #75
                                Use Intel Flash Image Tool, Open your existing bios(with late display). Just Change Intel me Region with same version and build Image. This will solve late display problem.
                                • MICHAEL_2013
                                  • Feb 2016
                                  • 59
                                  • Colombia
                                  #76
                                  Please anyone help me to unlock my hp 820 G2?
                                  • imranromi
                                    • Jan 2015
                                    • 1290
                                    • Pakistan
                                    #77
                                    Re: Please anyone help me to unlock my hp 820 G2?
                                    Originally posted by michael_2013
                                    please anyone help me to unlock my hp 820 g2
                                    try this and reply.
                                    • effektiveddd
                                      • Jun 2017
                                      • Poland
                                      #78
                                      Someone can fix my region on bios file ?
                                      HP 820 g2
                                      • imranromi
                                        • Jan 2015
                                        • 1290
                                        • Pakistan
                                        #79
                                        Originally posted by effektiveddd
                                        someone can fix my region on bios file ?
                                        Hp 820 g2
                                        bios problem what?
                                        • jasko_jacker
                                          • Oct 2014
                                          • 1140
                                          • italy
                                          #80
                                          HP 820 g2
                                          If the system start check with MEinfo.exe
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • TacticalFahrrad
                                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                            by TacticalFahrrad
                                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                            06-30-2025, 04:09 AM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • James Maxwell
                                            HP DM1-4000er Bios Dump needed
                                            by James Maxwell
                                            I badly need bios dump for HP DM1-4000er,
                                            Model: HP DM1-4000er
                                            Motherboard: DA0NM9MB6D0 REV.D
                                            Product: QJ490EA#ACB
                                            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                            10-28-2024, 05:38 PM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
