how to extract lenovo bios exe file
  • teqcom
    • Nov 2015
    • 311
    • malasyia
    how to extract exe file for lenovo bios exe
  • Claudio Silva
    • Feb 2013
    • 94
    • Portugal
    Re: how to extract exe file
    Try with Universal extractor
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      it depends of format of exe file or compression implemented
      (sometimes file have overlay, sometimes compressed exe in resources, etc...)
      this is inno scripted setup module which has specific compression
      you can use this tool to unpack
      Code:
      http://sourceforge.net/projects/innounp/files/
      anyways here is upacked files
      but bios extracted is uefi capsule file, not plain bin or rom so it cannot be flashed bu itself it need more work
      good luck
      Im Back... sort of...
      • teqcom
        • Nov 2015
        • 311
        • malasyia
        thx a lot
        • Marco_compucell
          • Feb 2012
          • 67
          • South Africa
          Thank You
          • Arash
            • Feb 2015
            • 4
            • Turkey
            Re: how to extract lenovo bios exe file
            how can İ use inno pack tool to extrack lenovo bios? pls help
              • 21023
              Try the GUI version https://sourceforge.net/projects/inn...p.exe/download
              • imranromi
                • Jan 2015
                • 1288
                • Pakistan
                Originally posted by SMDFlea
                #SMDFlea How to extract this bios Or what tool i use have idea thanks
                https://pcsupport.lenovo.com/vn/en/p...me=BIOS%2FUEFI
                  • 21023
                  Use the latest version of innoextract .
                  https://constexpr.org/innoextract/fi....8-windows.zip
                  Usage
                  To extract a setup file to the current directory run:
                  innoextract <file>
                  The extracted files will go into the app folder. Delete that app folder before you use innoextract again with another bios.
                  • imranromi
                    • Jan 2015
                    • 1288
                    • Pakistan
                    Usage
                    innoextract <file>
                    Thanks.
                    • Donet
                      • Jul 2015
                      • 11
                      • España
                      After using innoextract you will get an exe file in the "app" folder. This can be expanded with 7zip. Within the resulting files is one .ROM that contains the binary. Just edit it with an hexdecimal editor and remove the header and the final part.
                      Also open with the editor the original dump file to recognize the header (usually 5A A5 F0) and look for it inside the .rom. The bios image starts one line before this header, and ends 8MB after (or 16, depending on sizeof the bios). You can select the entire image (80000(H)), cut it , and paste on a new file. Save this as Biosxxxx.bin and That's all!
                      Sorry my bad english, and thank you Google translator!
                      • Donet
                        • Jul 2015
                        • 11
                        • España
                        Sorry. The size for 8MB bios is 800000(h).
                        • Antimatt3r
                          • Jul 2020
                          • 8
                          • Romania
                          Hey guys.
                          Could anyone please help me extract the bin file from this bios, for Lenovo V110-15IAP ?
                          I tried using innoextract , but I got got a .cap file and a .bin file, but the bin file is too small I think, the .cap file on the other hand seems to be around the proper size, 9MB or so.
                          The problem is that if I try to use the .cap file with CH341A it gives an error "file length beyond range will be ignored". I even tried converting the .cap file to .bin, but it gives the same error.
                          • lapfix
                            • Mar 2020
                            • 2733
                            • my workshop
                            The cap file is what you need to make your bios , as ala borbe say ( post 3) : but bios extracted is uefi capsule file, not plain bin or rom so it cannot be flashed bu itself it need more work.
                            so you need a HxD and your old dump to create your bios , maybe this tutorial help you :https://www.youtube.com/watch?v=7qESTVi_DVg&t=150s.
                              • 21023
                              You need to use a hex editor to make the bios the correct size.The smaller file is an EC update,ignore that.
                              The 1MCN54WW.cap CAP header length is 318 ,select block 0-317 delete it.Then select block 0-7FFFFF ,(or length 800000) ,copy it into a new file and save it.Find your old DMI info in your old bios backup,if you have one, and copy it to the new bios.If you do have a bios backup post it in a new thread if you get stuck.
                              EDIT: Watch the youtube vid posted by @lapfix or follow the second half of this guide - https://www.badcaps.net/forum/showthread.php?t=80861
                              • Antimatt3r
                                • Jul 2020
                                • 8
                                • Romania
                                Thanks man, I'll try and see if I can manage editing it using that tutorial.
                                Thanks for the help. I'll try doing that.
                                I will post the backup file tomorrow in this thread.
                                • Brzobub
                                  • Mar 2021
                                  • 16
                                  • Slovenia
                                  can you please help me extracting Lenovo Bios ?
                                  Legion 5-15ACH6H Laptop (Lenovo) - Type 82JU, serial PF3PS60T, GigaDevice 25LR128DSIG UG5963 AJ2136
                                  Thank you
                                  BR
                                  • peste
                                    • Dec 2016
                                    • 12872
                                    • ROMANIA
                                    Thank you
                                    BR
                                    you have everything you need at post #5...
                                    https://www.badcaps.net/forum/troubl...st#post1752856
                                    • Brzobub
                                      • Mar 2021
                                      • 16
                                      • Slovenia
                                      Did that, no change. Can someone help me.
                                      Thank you
                                      BR
                                      • survivalbloke
                                        Unable to extract bios file from Lenovo bios exectuable
                                        by survivalbloke
                                        I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                        Code:
                                        "innoextract 7wcn38ww.exe"
                                        it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                        The trouble I'm having is that I'm not getting the newly...
                                        06-12-2024, 07:55 AM
                                      • survivalbloke
                                        Unable to extract Lenovo BIOS file from installer
                                        by survivalbloke
                                        I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                                        I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                                        How can...
                                        07-16-2025, 03:21 PM
                                      • Forest79
                                        by Forest79
                                        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                        07-23-2023, 07:39 AM
                                      • Jk KIM
                                        Lenovo Ideapad 5 15ITL05 Bios File extract
                                        by Jk KIM
                                        Hi
                                        I need to extract bin file from bios update file which downloaded at Lenovo web site.
                                        Pls extract bin file from exe file...
                                        I attached exe file!
                                        Thx!...
                                        02-03-2023, 07:40 AM
                                      • pcwhiz24
                                        Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                        by pcwhiz24
                                        Model: Lenovo IdeaPad 3 14ADA05 81W0
                                        S/N: PF2BZS7D
                                        I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                        I already have a CH341A programmer...
                                        04-07-2025, 07:10 PM
