how to extract exe file for lenovo bios exe
how to extract lenovo bios exe file
Re: how to extract exe file
it depends of format of exe file or compression implemented
(sometimes file have overlay, sometimes compressed exe in resources, etc...)
this is inno scripted setup module which has specific compression
you can use this tool to unpack
anyways here is upacked filesCode:http://sourceforge.net/projects/innounp/files/
but bios extracted is uefi capsule file, not plain bin or rom so it cannot be flashed bu itself it need more work
good luckAttached FilesIm Back... sort of...
Re: how to extract lenovo bios exe file
Try the GUI version https://sourceforge.net/projects/inn...p.exe/downloadComment
#SMDFlea How to extract this bios Or what tool i use have idea thanksTry the GUI version https://sourceforge.net/projects/inn...p.exe/download
https://pcsupport.lenovo.com/vn/en/p...me=BIOS%2FUEFIComment
Use the latest version of innoextract .#SMDFlea How to extract this bios Or what tool i use have idea thanks
https://constexpr.org/innoextract/fi....8-windows.zip
Usage
To extract a setup file to the current directory run:
innoextract <file>
The extracted files will go into the app folder. Delete that app folder before you use innoextract again with another bios.Last edited by SMDFlea; 01-23-2020, 10:12 AM.Comment
Thanks.Use the latest version of innoextract .
Usage
innoextract <file>
The extracted files will go into the app folder. Delete that app folder before you use innoextract again with another bios.Comment
After using innoextract you will get an exe file in the "app" folder. This can be expanded with 7zip. Within the resulting files is one .ROM that contains the binary. Just edit it with an hexdecimal editor and remove the header and the final part.
Also open with the editor the original dump file to recognize the header (usually 5A A5 F0) and look for it inside the .rom. The bios image starts one line before this header, and ends 8MB after (or 16, depending on sizeof the bios). You can select the entire image (80000(H)), cut it , and paste on a new file. Save this as Biosxxxx.bin and That's all!
Sorry my bad english, and thank you Google translator!
Hey guys.
Could anyone please help me extract the bin file from this bios, for Lenovo V110-15IAP ?
I tried using innoextract , but I got got a .cap file and a .bin file, but the bin file is too small I think, the .cap file on the other hand seems to be around the proper size, 9MB or so.
The problem is that if I try to use the .cap file with CH341A it gives an error "file length beyond range will be ignored". I even tried converting the .cap file to .bin, but it gives the same error.Attached FilesComment
The cap file is what you need to make your bios , as ala borbe say ( post 3) : but bios extracted is uefi capsule file, not plain bin or rom so it cannot be flashed bu itself it need more work.
so you need a HxD and your old dump to create your bios , maybe this tutorial help you :https://www.youtube.com/watch?v=7qESTVi_DVg&t=150s.Comment
You need to use a hex editor to make the bios the correct size.The smaller file is an EC update,ignore that.
The 1MCN54WW.cap CAP header length is 318 ,select block 0-317 delete it.Then select block 0-7FFFFF ,(or length 800000) ,copy it into a new file and save it.Find your old DMI info in your old bios backup,if you have one, and copy it to the new bios.If you do have a bios backup post it in a new thread if you get stuck.
EDIT: Watch the youtube vid posted by @lapfix or follow the second half of this guide - https://www.badcaps.net/forum/showthread.php?t=80861Last edited by SMDFlea; 07-09-2020, 12:41 PM.Comment
Thanks man, I'll try and see if I can manage editing it using that tutorial.The cap file is what you need to make your bios , as ala borbe say ( post 3) : but bios extracted is uefi capsule file, not plain bin or rom so it cannot be flashed bu itself it need more work.
Thanks for the help. I'll try doing that.You need to use a hex editor to make the bios the correct size.The smaller file is an EC update,ignore that.
I will post the backup file tomorrow in this thread.Last edited by Antimatt3r; 07-09-2020, 12:40 PM.Comment
can you please help me extracting Lenovo Bios ?
Legion 5-15ACH6H Laptop (Lenovo) - Type 82JU, serial PF3PS60T, GigaDevice 25LR128DSIG UG5963 AJ2136
Thank you
BR
Every donation made will go towards server fees and maintenance costs.Comment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the commandit should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.Code:
"innoextract 7wcn38ww.exe"
The trouble I'm having is that I'm not getting the newly...-
I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
How can... -
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by Jk KIMHi
I need to extract bin file from bios update file which downloaded at Lenovo web site.
Pls extract bin file from exe file...
I attached exe file!
Thx!...-
02-03-2023, 07:40 AM -
- Loading...
