Hp 620 bios
  • Esse
    • Apr 2014
    • 317
    • TOGO
    Hp 620 bios
    Please i need bios or dump for this machine
    This is old bios
  • imranromi
    • Jan 2015
    • 1292
    • Pakistan
    Re: Hp 620 bios
    Ok check new bios
    • Esse
      • Apr 2014
      • 317
      • TOGO
      Re: Hp 620 bios
      please help me
      • Esse
        • Apr 2014
        • 317
        • TOGO
        Re: Hp 620 bios
        Please ala_borbe can you help me with the bios of this machine
        • angel-boy
          • 550
          • Romania
          Re: Hp 620 bios
          Originally posted by imranromi
          Ok check new bios
          see file attached
          • Esse
            • Apr 2014
            • 317
            • TOGO
            Re: Hp 620 bios
            please will this bios work?since the old backup file size (1.17 Mb) is big different from the new(20.3 kb)
            • imranromi
              • Jan 2015
              • 1292
              • Pakistan
              Re: Hp 620 bios
              Brother plz send me motherboard model i check again.
              • imranromi
                • Jan 2015
                • 1292
                • Pakistan
                Re: Hp 620 bios
                try this bios if bios is ok plz reply me
                this bios 25Q16/25L16.
                • Esse
                  • Apr 2014
                  • 317
                  • TOGO
                  Re: Hp 620 bios
                  other information about this machine:
                  Serial:5CG114076G
                  Product:WZ294UT#ABA
                  • Esse
                    • Apr 2014
                    • 317
                    • TOGO
                    Re: Hp 620 bios
                    I have also this information on the motherboard:
                    HSTNN-185C-4
                    HSTNN-185C-5
                    • Esse
                      • Apr 2014
                      • 317
                      • TOGO
                      Re: Hp 620 bios
                      Please imranromi,the two bios you gave me dont work.
                      Any help please
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        Re: Hp 620 bios
                        if this bios does not work, its not bios problem
                        Im Back... sort of...
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          Re: Hp 620 bios
                          does anyone have schematics for
                          HSTNN-185C-4
                          HSTNN-185C-5
                          i broke 1st pin on spio bios ic
                          • meritosari
                            • Oct 2010
                            • 774
                            • Indonesia
                            Re: Hp 620 bios
                            HSTNN-185C-4
                            HSTNN-185C-5
                            I think these code for Villemont 2010 intel-uma
                            http://notebook1.ru/forma1/download/file.php?id=36477
                            https://***********/media/hp-620-inv...n.162/download
                            • ala_borbe
                              aka Donald
                              • 1625
                              • Malta
                              Re: Hp 620 bios
                              thank you... fixed
                              also nec capacitor had to go, i had freezing with black screen but backlight stayed on
                              • dahnking
                                • Apr 2018
                                • 265
                                • kenya
                                Re: Hp 620 bios
                                Working 100% tested
                                Thank you bro ala_borbe
                                • watanirar
                                  • Dec 2018
                                  • 24
                                  • youssoufia
                                  Re: Hp 620 bios
                                  Thank you for
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                  • mkdj
                                    by mkdj
                                    Dear all,
                                    10-19-2025, 04:41 AM
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • zlr8r
                                    Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                    by zlr8r
                                    Greetings
                                    I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                    Serial Number: 5CG3202C16
                                    Product #/SKU: 739P0AV
                                    CT Number: PRTUE00WBI30YX
                                    Description: HP ZBook Firefly 14 inch G10
                                    BuildID: 23WWWGAZ602#SABU#DABU
                                    Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                    MAC address not found.
                                    • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                    10-28-2025, 01:56 PM
                                  • haitham sharabati
                                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                    by haitham sharabati
                                    Hello engineers 😀,
                                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                    🔧 Device Info:
                                    - Model: HP 15-da2007ne
                                    - Product Number: 8XF55EA#ABV
                                    - Serial Number: CND0338P0D
                                    - CPU: Intel Celeron N4000
                                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                    💀 Problem:😅
                                    - Device shows “Administrator Password”...
                                    08-07-2025, 04:54 AM
