Asus X52JT Bios Dump
  • delphi_firebird
    • Mar 2015
    • 36
    • France
    Hello Guys ,
    I need the bios dump of Asus X52JT ( MB : K52JT ) .
    I found this one : http://www.elektroda.pl/rtvforum/topic2881904.html
    But i dont knew why the cpu fan works at max speed and dont stop
    Thank you by advance
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus X52JT Bios Dump
    do you have backup of nonworking bios? post it here
    or try this bios
    Im Back... sort of...
    • AhmedNSane
      AhmedNSane commented
      Editing a comment
      Hello, Donald! Is it possible to use AMIBCP to fix the max fan speed issue for K52Je (while the board says K52JR REV 2.2)?
  • sel3370
    • Aug 2017
    • 18
    • turkey
    Thank you bıos ok
    • GENCDESTEK
      • Sep 2018
      • 10
      • Türkiye
      • eminemo
        • Feb 2023
        • bucuresti
        I downloaded bios versions for the k52jt from the Asus official website and nothing works, the processor fan turns faster and that's it. bios ala_borbe works. thanks!
        • Kemer
          • Apr 2023
          • 37
          • Turkey
          High and constant acpi temp, low cpu, gpu temps
          I need your knowledge and experience. I have an Asus K52J() laptop. I bought it from someone. The fan starts to rotate at a constant speed (~5200 rpm) 30 seconds after the computer turned on and continues until turned off.
          CPU and gpu temperatures are around 35 degrees. Temp1 temperature is 88 degrees Celsius (not changing at all). The air blown by the fan is considered cool. Copper coolant can be called warm. No other problems.
          It reads K52JT at the bottom of the case, and K52JT is written on the RAM slots. But Bios version K52JU.206. I re-flashed lower and same versions from Asus site but nothing changed.
          I tried flashing the K52JT as it says under the case but WinFlash refused it (version does not match). Easyflash in the bios also showed the same error.
          I also tried the dump file named "K52JT Fixed Clean ME" but it showed "file size is not valid" error (~4KB) and rejected it.
          I don't know if the problem is in the bios, but the models are different (K52JT and K52JU) in the motherboard and bios.
          I got 3 bios dumps with the help of FPTW.exe in case anyone wants to help. Every byte is exactly the same. They are also attached.
          I'm tired of the fan noise.
          • Kemer
            • Apr 2023
            • 37
            • Turkey
            So (finally) I solved my problem with the help of the file that ala_borbe added. I am grateful to ala_borbe for this. Thanks to forum moderators and the other members who answered my questions.
            • Kemer
              • Apr 2023
              • 37
              • Turkey
              And an update... It doesn't start with just battery but if I plug the charger also and push the pwr butt it can trigger. Then if I plug off the charger (one sec after pwr butt) it goes on boot.
              More, windows doesn't detect battery (notif. area) while the power coming only from batt. İt charges the batt and amber indicator led showing this but the led never turn to green.
              Any suggestion please??
              • qayyum786
                • Aug 2018
                • 1933
                • INDIA
                Originally posted by kemer
                and an update... It doesn't start with just battery but if i plug the charger also and push the pwr butt it can trigger. Then if i plug off the charger (one sec after pwr butt) it goes on boot.
                More, windows doesn't detect battery (notif. Area) while the power coming only from batt. İt charges the batt and amber indicator led showing this but the led never turn to green.
                post originale bios backup if you have so some one can fix it
                • Kemer
                  • Apr 2023
                  • 37
                  • Turkey
                  Thanks but I don't have. I bought it from someone. I don't know the reason but the bios wasn't originale, already. So, I don't have.
                  • Kemer
                    • Apr 2023
                    • 37
                    • Turkey
                    My device model is K52JT-SX172R. When I bought this it seemed to have K52JU in the bios but it was working. The only problem was that the fan was constantly running at maximum speed. The bios file attached to the post above (https://www.badcaps.net/forum/attach...7&d=1445162421) solved the fan issue. But now I have a battery problem.
                    I wonder if cleaning ME Region in the bios file may have caused this battery issue? Can we check a value in the bios file that may be the cause of this problem with the hex editor?
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      Originally posted by Kemer
                      ...it seemed to have K52JU in the bios but it was working.
                      Try the bios from this post:
                      https://www.badcaps.net/forum/showth...441#post967441
                      Become a Badcaps supporter
                      Thanks to all supporters.​
                      • Kemer
                        • Apr 2023
                        • 37
                        • Turkey
                        Originally posted by Vesko356
                        Thanks for your interest and help. I'll keep this file in mind, but it's not the model on the motherboard label. I prefer the one that suits my model.
                        I wonder, if something go wrong while cleaning the ME Region?
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          Upload the image with the motherboard stickers.
                          K52JT Clean:
                          • Kemer
                            • Apr 2023
                            • 37
                            • Turkey
                            Sure. Here they are.
                            • Kemer
                              • Apr 2023
                              • 37
                              • Turkey
                              I'm having difficulties about loading images. Getting page load fault. I'll try to add next pic in another post.
                              OK, I could load.
                              • Kemer
                                • Apr 2023
                                • 37
                                • Turkey
                                K52JT Clean:
                                Thank you. I am grateful to you too.. What kind of bios is this? Me Region cleaned or asus service binary or ??
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  Virgin dump for Asus K52JT - should be OK for your machine, try it.
                                  • Kemer
                                    • Apr 2023
                                    • 37
                                    • Turkey
                                    Thank you very much. You're great. OK, I will but actually do it with the help of a technician. I do not have enough tools and experience.
                                    I especially won't forget the help of you, ala_borbe, the moderators of this forum and other helpful members. Kind regards...
                                    • razor_amd
                                      by razor_amd
                                      12-15-2020, 07:07 PM
                                    • DynaxSC
                                      by DynaxSC
                                      06-14-2024, 03:49 PM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • kcp0085
                                      Request BIOS dump for ASUS FA617NS-A16.R77600
                                      by kcp0085
                                      Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                                      I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                                      Specs:
                                      - ASUS TUF FA617NS-A16
                                      - CPU: AMD Ryzen 7
                                      - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                                      If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                                      Thanks in advance!​
                                      05-02-2025, 12:52 AM
