Asus Bios K52JU
  • Tuga_75
    Banned
    • Apr 2015
    • 13
    • Portugal
    Asus Bios K52JU
    Good day Sir any one have this bios for this pc
    • 22286
    Re: Asus Bios K52JU
    Post your bios backup .
    • Tuga_75
      Banned
      • Apr 2015
      • 13
      • Portugal
      Re: Asus Bios K52JU
      good day i as doing a usb bios update and the power as cut in de end off the update i dont have any backup.
      Paulo
        • 22286
        Re: Asus Bios K52JU
        Ok so the bios will be corrupt,you need to backup the corrupt bios and post it here. You will need an SPI bios programmer.If you can`t desolder the chip you also need a sop8 clip .
        https://www.aliexpress.com/item/32793476447.html
        • Tuga_75
          Banned
          • Apr 2015
          • 13
          • Portugal
          Re: Asus Bios K52JU
          a have fash this bios on the chip but isnt the original and have any luck.
          Best regards
          Paulo
            • 22286
            Re: Asus Bios K52JU
            When you tried to flash it, hopefully it retained the DMI info ,serial number and the MAC address.If you post your bios backup as suggested the bios can be fixed.
            • Tuga_75
              Banned
              • Apr 2015
              • 13
              • Portugal
              Re: Asus Bios K52JU
              I made a dump off the data on the chip
                • 22286
                Re: Asus Bios K52JU
                You have a bios programmer ? , make another backup .
                • Tuga_75
                  Banned
                  • Apr 2015
                  • 13
                  • Portugal
                  Re: Asus Bios K52JU
                  this is the actual backup off the pc
                    • 22286
                    Re: Asus Bios K52JU
                    read post #8 again.You have a bios programmer ? ,if so what model is it, have you desoldered the bios chip or are you using a sop8 clip ??????.
                    • Tuga_75
                      Banned
                      • Apr 2015
                      • 13
                      • Portugal
                      Re: Asus Bios K52JU
                      I am using a using a sop8 clip
                      • Tuga_75
                        Banned
                        • Apr 2015
                        • 13
                        • Portugal
                        Re: Asus Bios K52JU
                        good day is i have the bios programer that you mentioned in the previous post i dint have the backup bios the file i have put in the forum are from wen i try to prog the chip original bios tha i have take from asus support for my notebook.
                        best regards
                        Paulo
                          • 22286
                          Re: Asus Bios K52JU
                          The clips are not very good,its easy to lose the connection.You will get a better backup if you can desolder the chip. The first bios you posted is seriously corrupt,because you`re using a clip,you should get a better backup than that.Hold the clip down with your hand,make another 2 backups !!! ,post them .
                          • Tuga_75
                            Banned
                            • Apr 2015
                            • 13
                            • Portugal
                            Re: Asus Bios K52JU
                            Tanks for our help i found a bios and ist now working id the same fault , it shut down in bios do to overheat in the cpu.
                            Best regards
                            Paulo
                              • 22286
                              Re: Asus Bios K52JU
                              Ok, you can`t fix them all. Can you post the bios you found,it might help someone else.
                              • Tuga_75
                                Banned
                                • Apr 2015
                                • 13
                                • Portugal
                                Re: Asus Bios K52JU
                                I found this bios and fix my bios problem.
                                Best regards
                                Paulo
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • grimacelord
                                  by grimacelord
                                  07-10-2025, 02:52 PM
                                • ferah831208
                                  help with bios decompose for Asus s5506ma
                                  by ferah831208
                                  I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                                  08-24-2025, 05:35 PM
                                • DynaxSC
                                  by DynaxSC
                                  06-14-2024, 03:49 PM
                                • chudofermer
                                  Asus Ally rc71l bios
                                  by chudofermer
                                  Hello!
                                  Received Asus Ally rc71l with the wrong bios.
                                  Have the original package and all serial numbers.
                                  Can anyone help me understand what is wrong?
                                  Condition:
                                  Received with an original box with all serial numbers
                                  Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                                  Got the flash dump, nothing found on DMI section
                                  No Windows key, just key ID on the box
                                  What is done:
                                  1. Flash the latest bios version with serial numbers...
                                  03-05-2025, 05:42 AM
