DMI data extraction from BIOS dump.
  • KEVSPIT
    • Sep 2015
    • 62
    • Malta
    Would it be possible to extract the DMI data from a BIOS dump on Windows?
    It can be done on Linux using the dmidecode application.
    I need to get the HP/Compaq serial number etc from the BIOS dump to be able to put it in the newly flashed system.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: DMI data extraction from BIOS dump.
    Clarify what you mean, the OEM-SLP keys are readily available at places like mydigitallife etc.
    Or are you talking about the SLIC itself?
    • KEVSPIT
      • Sep 2015
      • 62
      • Malta
      No, not the SLIC. I need to get the HP Model number, serial number, PCID, OS Type variables from the BIOS dump.
      I know how to get it from a working system, but not from a saved dump.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yea it should be possible, look in the SMBIOS using for example mmtool if it's an AMI based BIOS
        • KEVSPIT
          • Sep 2015
          • 62
          • Malta
          Yes that's exactly what I need. Is there a tool for Insyde BIOSes but?
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            There are hardly any tools for Insyde unfortunately. However, the relevant serial codes can be found on the back of the computer, under the battery compartment. The data can then be written using the HPBQ138.EXE tool ran from a DOS bootable USB drive.
            A working TV? How boring!
            • volinakis
              • Jan 2021
              • 2624
              • N/A
              RW Everything
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
              • vinaypundith
                Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                by vinaypundith
                I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                So, I'm looking for a BIOS dump for this machine - a 16MB one....
                08-03-2024, 12:32 PM
