DMI data extraction from BIOS dump.
  • KEVSPIT
    • Sep 2015
    • 62
    • Malta
    Would it be possible to extract the DMI data from a BIOS dump on Windows?
    It can be done on Linux using the dmidecode application.
    I need to get the HP/Compaq serial number etc from the BIOS dump to be able to put it in the newly flashed system.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: DMI data extraction from BIOS dump.
    Clarify what you mean, the OEM-SLP keys are readily available at places like mydigitallife etc.
    Or are you talking about the SLIC itself?
    • KEVSPIT
      • Sep 2015
      • 62
      • Malta
      No, not the SLIC. I need to get the HP Model number, serial number, PCID, OS Type variables from the BIOS dump.
      I know how to get it from a working system, but not from a saved dump.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yea it should be possible, look in the SMBIOS using for example mmtool if it's an AMI based BIOS
        • KEVSPIT
          • Sep 2015
          • 62
          • Malta
          Yes that's exactly what I need. Is there a tool for Insyde BIOSes but?
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            There are hardly any tools for Insyde unfortunately. However, the relevant serial codes can be found on the back of the computer, under the battery compartment. The data can then be written using the HPBQ138.EXE tool ran from a DOS bootable USB drive.
            A working TV? How boring!
            • volinakis
              • Jan 2021
              • 2877
              • N/A
              RW Everything
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                by haitham sharabati
                Hello engineers 😀,
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                💀 Problem:😅
                08-07-2025, 04:54 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
