e6400 bios dump
  • Mario
    • Sep 2007
    • 64
    e6400 bios dump
    I have a e6400 with bios password. Does anyone have a bios dump of the chip? I see there are a few bios bios chips on the laptop. Do i have to reflash all?
  • wallyoz7
    • Mar 2015
    • 21
    Re: e6400 bios dump
    I have a dump file for the e6400 .
    • Mario
      • Sep 2007
      • 64
      Re: e6400 bios dump
      Would you be able to share it with us? Do you know if its just one chip to replace to remove password and or computrace? I got one with password and one with computrace and password
      • wallyoz7
        • Mar 2015
        • 21
        Re: e6400 bios dump
        Its one chip,(winbond)
        • wallyoz7
          • Mar 2015
          • 21
          Re: e6400 bios dump
          I think the e6400 laptops can be unlocked through this website
          http://bios-pw.org/
          • hbissou
            • Mar 2015
            • 11
            • morocco
            Re: e6400 bios dump
            for motherboard : LA-3805P
            • Mario
              • Sep 2007
              • 64
              Re: e6400 bios dump
              Thank you hbissou.I tried flashing that. bios revision changed. But computrace is still there. Does anyone know if that is removable by reflashing any of the chips?
              @ wallyoz7 the bios you provided is not a dump from computer. The dump from the bios update does not include files for serial and the little details from the computer...
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                Re: e6400 bios dump
                i read somewhere that there is another chip with pass inside which turns on computrace so you need to flash that from laptop with no password if i recall good
                Im Back... sort of...
                • Mario
                  • Sep 2007
                  • 64
                  Re: e6400 bios dump
                  Ah. Thank you for the info. I read that too. I think they said its on the ec... Which I think is not a chip I can read with my tools. Does anyone have any suggestions?
                  • wallyoz7
                    • Mar 2015
                    • 21
                    Re: e6400 bios dump
                    From what I know is that computrace is located within the Operating System and the bios chip together. If both bios chip and O.S. are erased and reprogrammed , then computrace will be erased for good. The software is called Remote Procedure Call (rpcnet.exe) by computrace also C:\WINDOWS\system32\svchost -k rpcss
                    • interzone
                      • Jun 2015
                      • 9
                      • france
                      Re: e6400 bios dump
                      this subject is a bit old,
                      But I think It could help some people to share my experience.
                      I bought a dell e6400 bios locked from ebay,
                      the administrative password was set in the bios, so I could not make any changes in the bios settings..
                      But the notebook was still able to boot from a usb key.
                      I first try the site http://bios-pw.org/
                      but the unlock password computed didnt work with my bios revision.
                      So I followed the procedure I found in this page:
                      http://honestpchelp.com/2015/downgra...00d630-series/
                      I first boot from a HirenCD USB key, (make with yumi multiboot)
                      then I forced a bios downgrade like this:
                      E6400A10.EXE /forceit
                      and now with the old bios revision,
                      the password computed on http://bios-pw.org/ works...
                      so you can remove the administrative password...
                      without needing to reflash the bios chip...
                      I hope it will help someone...
                      (and sorry for my bad english )
                      • raihan
                        • Feb 2016
                        • 42
                        • Bangladesh
                        Re: e6400 bios dump
                        need bios plss
                        • Me.Orouji
                          • Dec 2015
                          • 117
                          • Iran
                          Re: e6400 bios dump
                          Try this
                          • Me.Orouji
                            • Dec 2015
                            • 117
                            • Iran
                            Re: e6400 bios dump
                            On Latitude Devices password stored on SMSC IO, Sorry my friend
                            • imranromi
                              • Jan 2015
                              • 1290
                              • Pakistan
                              Re: e6400 bios dump
                              TRY THIS 100% WORKING WHEN FLASH BIOS CHECK THE SERVICE TAG LAST 4 DIGIT 2A7B
                              TRY THIS LINK
                              https://bios-pw.org/
                              • joshua Emmanuel
                                • Oct 2017
                                • 7
                                • Nigeria
                                Re: e6400 bios dump
                                good day to you all, I have dell latitude e6400 LA-3803P rev:2.0 that fell down and din't display when powered after the fall. After several attempts it displayed, it hanged while booting. I then off the laptop, it refuse to on again only flashing light. If I press the power botten keeps flashing light as restarting but the fan not rotating. Pls I need your help on what to do, I appreciate.
                                • suneth
                                  • Oct 2016
                                  • 8
                                  • Sri Lanka
                                  Re: e6400 bios dump
                                  TRY THIS LINK
                                  THANKS YOU SAVE ME!!! its work!!!
                                  • inforakeshagarwal
                                    • Jul 2019
                                    • INDIA
                                    Re: e6400 bios dump
                                    Hell Everyone,
                                    Please share dump file of Dell Latitude E6400 jbl00 la-3801p 4 mb
                                    It's vaey urgent kindly share as soon as possible
                                    • peste
                                      • 13315
                                      • ROMANIA
                                      Re: e6400 bios dump
                                      Originally posted by inforakeshagarwal
                                      Hell Everyone,
                                      post the original bios, backup ..
                                      • oam007
                                        • Jan 2020
                                        • 10
                                        • morocco
                                        Re: e6400 bios dump
                                        Thank you my friends
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • greelidd
                                          K6604J Vivobook RTX 4070 BIOS Dump Request
                                          by greelidd
                                          Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                                          Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                                          09-01-2025, 06:14 PM
