e6400 bios dump
  • Mario
    • Sep 2007
    • 64
    e6400 bios dump
    I have a e6400 with bios password. Does anyone have a bios dump of the chip? I see there are a few bios bios chips on the laptop. Do i have to reflash all?
  • wallyoz7
    • Mar 2015
    • 21
    Re: e6400 bios dump
    I have a dump file for the e6400 .
    • Mario
      • Sep 2007
      • 64
      Re: e6400 bios dump
      Would you be able to share it with us? Do you know if its just one chip to replace to remove password and or computrace? I got one with password and one with computrace and password
      • wallyoz7
        • Mar 2015
        • 21
        Re: e6400 bios dump
        Its one chip,(winbond)
        • wallyoz7
          • Mar 2015
          • 21
          Re: e6400 bios dump
          I think the e6400 laptops can be unlocked through this website
          http://bios-pw.org/
          • hbissou
            • Mar 2015
            • 11
            • morocco
            Re: e6400 bios dump
            for motherboard : LA-3805P
            • Mario
              • Sep 2007
              • 64
              Re: e6400 bios dump
              Thank you hbissou.I tried flashing that. bios revision changed. But computrace is still there. Does anyone know if that is removable by reflashing any of the chips?
              @ wallyoz7 the bios you provided is not a dump from computer. The dump from the bios update does not include files for serial and the little details from the computer...
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                Re: e6400 bios dump
                i read somewhere that there is another chip with pass inside which turns on computrace so you need to flash that from laptop with no password if i recall good
                Im Back... sort of...
                • Mario
                  • Sep 2007
                  • 64
                  Re: e6400 bios dump
                  Ah. Thank you for the info. I read that too. I think they said its on the ec... Which I think is not a chip I can read with my tools. Does anyone have any suggestions?
                  • wallyoz7
                    • Mar 2015
                    • 21
                    Re: e6400 bios dump
                    From what I know is that computrace is located within the Operating System and the bios chip together. If both bios chip and O.S. are erased and reprogrammed , then computrace will be erased for good. The software is called Remote Procedure Call (rpcnet.exe) by computrace also C:\WINDOWS\system32\svchost -k rpcss
                    • interzone
                      • Jun 2015
                      • 9
                      • france
                      Re: e6400 bios dump
                      this subject is a bit old,
                      But I think It could help some people to share my experience.
                      I bought a dell e6400 bios locked from ebay,
                      the administrative password was set in the bios, so I could not make any changes in the bios settings..
                      But the notebook was still able to boot from a usb key.
                      I first try the site http://bios-pw.org/
                      but the unlock password computed didnt work with my bios revision.
                      So I followed the procedure I found in this page:
                      http://honestpchelp.com/2015/downgra...00d630-series/
                      I first boot from a HirenCD USB key, (make with yumi multiboot)
                      then I forced a bios downgrade like this:
                      E6400A10.EXE /forceit
                      and now with the old bios revision,
                      the password computed on http://bios-pw.org/ works...
                      so you can remove the administrative password...
                      without needing to reflash the bios chip...
                      I hope it will help someone...
                      (and sorry for my bad english )
                      • raihan
                        • Feb 2016
                        • 41
                        • Bangladesh
                        Re: e6400 bios dump
                        need bios plss
                        • Me.Orouji
                          • Dec 2015
                          • 117
                          • Iran
                          Re: e6400 bios dump
                          Try this
                          • Me.Orouji
                            • Dec 2015
                            • 117
                            • Iran
                            Re: e6400 bios dump
                            On Latitude Devices password stored on SMSC IO, Sorry my friend
                            • imranromi
                              • Jan 2015
                              • 1288
                              • Pakistan
                              Re: e6400 bios dump
                              TRY THIS 100% WORKING WHEN FLASH BIOS CHECK THE SERVICE TAG LAST 4 DIGIT 2A7B
                              TRY THIS LINK
                              https://bios-pw.org/
                              • joshua Emmanuel
                                • Oct 2017
                                • 7
                                • Nigeria
                                Re: e6400 bios dump
                                good day to you all, I have dell latitude e6400 LA-3803P rev:2.0 that fell down and din't display when powered after the fall. After several attempts it displayed, it hanged while booting. I then off the laptop, it refuse to on again only flashing light. If I press the power botten keeps flashing light as restarting but the fan not rotating. Pls I need your help on what to do, I appreciate.
                                • suneth
                                  • Oct 2016
                                  • 8
                                  • Sri Lanka
                                  Re: e6400 bios dump
                                  TRY THIS LINK
                                  THANKS YOU SAVE ME!!! its work!!!
                                  • inforakeshagarwal
                                    • Jul 2019
                                    • INDIA
                                    Re: e6400 bios dump
                                    Hell Everyone,
                                    Please share dump file of Dell Latitude E6400 jbl00 la-3801p 4 mb
                                    It's vaey urgent kindly share as soon as possible
                                    • peste
                                      • Dec 2016
                                      • 12778
                                      • ROMANIA
                                      Re: e6400 bios dump
                                      Originally posted by inforakeshagarwal
                                      Hell Everyone,
                                      post the original bios, backup ..
                                      • oam007
                                        • Jan 2020
                                        • 10
                                        • morocco
                                        Re: e6400 bios dump
                                        Thank you my friends
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
