need dell latitude e4300 bios dump
  • helderfb
    • May 2014
    • 16
    • portugal
    someone could post dell latitude e4300 pp13s full bios dump
    thank
  • helderfb
    • May 2014
    • 16
    • portugal
    Re: need dell latitude e4300 bios dump
    someone please
    • sanehdeep2012
      • Oct 2013
      • 139
      • india
      I AHVE TRIED BUT UNABLE TO FIND THE REQUIRED FILE
      BUT MAY THE FOLLOWING WILL HELP YOU
      Re: Help To extract Dell EXE BIOS
      I'm not sure exactly what you want, but I'm guessing that you cannot boot the laptop even into BIOS mode because the BIOS is corrupt.
      Which laptop?
      Most laptops (actually, most BIOSs) have an emergency recovery mode whereby it is possible to force a BIOS update even if the system cannot boot.
      Try this:
      Download the required BIOS file; let's call it x.exe
      Extract the HDR file from the x.exe with: "x.exe -writehdrfile". This will give a file x.hdr
      Copy x.hdr to a formatted diskette, perhaps on a USB-diskette (might even work on a pen drive)
      Rename x.hdr according to the list below
      Unplug the adapter and remove the battery from the laptop
      Hold "END" down on the keyboard while you plugin the Adapter
      The battery light should come on red
      Release "END" - the laptop power should up
      Wait while the diskette is read, this might take some time (you'll hear it)
      The laptop should shut down or restart itself
      Job done!
      Dell Latitude D410 : VENI???.BIN, VENI???.HDR, VENI???.HDC, VEN????.BIN, VEN????.HDR
      Dell Latitude D420 : CRO????.bin, CRO????.hdr, CRO????.hdc, D420???.bin, D420???.hdr
      Dell Latitude D430 : CAR????.bin, CAR????.hdr, CAR????.hdc, D430???.bin, D430???.hdr
      Dell Latitude D610 : AZED???.bin, AZED???.hdr, AZED???.hdc, AZE????.bin, AZE????.hdr
      Dell Latitude D620 : TRAV???.bin, TRAV???.hdr, TRAV???.hdc, D620???.bin, D620???.hdr
      Dell Latitude D630 : BRIS???.bin, BRIS???.hdr, BRIS???.hdc, D630???.bin, D630???.hdr
      Dell Latitude E4300 : LOLA???.bin, LOLA???.hdr, LOLA???.hdc, E4300??.bin, E4300??.hdr
      Dell Latitude E6400 : RSH????.bin, RSH????.hdr, RSH????.hdc, E6400??.bin, E6400??.hdr
      If your laptop is not listed, try google.
      • cyberhack
        • Feb 2013
        • 466
        • Uk
        Here I have done what sanehdeep has said
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          read your old bios and post here, i might help you
          Im Back... sort of...
          • helderfb
            • May 2014
            • 16
            • portugal
            old bios full backup
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              i found this
              E4300A26.exe /Writeromfile
              E4300A26.exe /Writehdrfile
              The Win32 exe file will execute in windows and It will then create a BiosFileName.ROM or BiosFileName.HDR in the current Directory
              Further command line options are as bellow.
              Classic
              Reportstatus
              Norburesults
              Rburesults
              Writeromfile
              Writehexfile
              Writehdrfile
              Wipeclean
              Wipeall
              Verbose
              Prgboot
              Noreboot
              Nopause
              Info
              Forcetype
              Forceit
              Factory
              Edvu
              Boot
              after looking and rebuilding your dump, result is the same file, same CRC, so 99% not bios problem
              • Kesavan
                • Aug 2016
                • 194
                • India
                Dell Latitude E4300 BIOS need
                I need BIOS BIN for Dell Latitude E4300
                MOBO : JAL10 LA-4151P REV: 1.0
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11191
                  • Viet Nam
                  Re: Dell Latitude E4300 BIOS need
                  Your file is badly damaged and cannot be recovered. This file was found via google search.
                  • Kesavan
                    • Aug 2016
                    • 194
                    • India
                    Thanks but not working to me
                    • gizaha
                      by gizaha
                      02-13-2024, 07:18 AM
                    • jhanra
                      by jhanra
                      in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                      11-02-2024, 04:19 AM
                    • TripTop
                      Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                      by TripTop
                      Hi
                      i have dell latitude E7270 with following symptoms:
                      - takes long time to restart.
                      - sometimes powers on and then off
                      - sometimes while working it just dies,
                      From googling online bios clean could possible resolve this?
                      i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                      As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                      I reinstall...
                      09-09-2024, 02:05 PM
                    • Loli Popu
                      DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                      by Loli Popu
                      Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                      12-13-2024, 08:29 AM
                    • mikeybass
                      by mikeybass
                      04-23-2025, 04:30 PM
