If that's a hybrid laptop(two video cards) then you should try to disable the Nvidia card in bios.
If I'm not wrong you have to install the Intel chipset driver first. Anyway you should have a normal resolution with the Intel graphics card even if the Nvidia is bad. If it's bad then you will get BSOD or lines on the screen.
hazardus like i mentioned , i tryed all ways , nvidia disabled , same shit , nvidia on and intel disabled same shit .. altough one thing i notice , if i have intel enables , or just intel , the device manager is with the yellow triangle meaning there are no resources , "try to remove hardware that are using same resources" message saying on the device)
.. and on bios impossible to disconnect nvidia , unless someone give me a good SLIC moded bios with option to disable grafic cards .
dam cmputer is sucking me all the bloody day
ok with fresh windows install . both gpu without drivers have the yellow triangle , for INTEL tells me there is no enough free resources to use this hardware ,
the nvidia tells me that this device cannot be innitialized
yes thats why im waiting for the master techman to rebuils a bios for me , my last resource before speaking with our (client store for he can speak with is client for the options)
hazardus , even without drivers for grafic it should never do this .. i should at least change resolution and the both hardwares should not give resources errors
If I didn't install the drivers for the N7110 then I couldn't set the resolution above 1024x768 I can't recall but maybe the default resolution was 640x480 but I'm not sure.
this is clearly something with bios ... now on windows instaled the winflashed for this asus frmo the K53SV support page .. when installing gives me a error that " sorry this program only supports asus notebooks"
new infos , i talk to the store and they speaked with client , they mention client , was complaining about machine sshutting down somethimes , but due to energy problems . and problems with battery .
alltough someone changed the bios of the computer .. since its a k53sj rom , instead of k53SV .. but image is still crazy .. techman help me out mate , have y ou fixed that bios for me ?
for that i must find a good old dump , but there is a asus rthat enter today same model , revision change only , but will try this bios and let see what happen
techman "robert" read my message the original bios foudn on the laptop is on the first post of this thread
FUCK YEAHHHHH (sorry the bad names) after all it was always a problem with bios ... this motherboard had a good bios , just removed one bios from one side to another and it work perfect solved ..
