HP g6-1030st bios dump
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    hi guys does anybody here have bios file for this laptop Hp G6-1030ST corei5. Board model is DA0R12MB6E0 quanta r12. Thanks in advance!
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: HP g6-1030st bios dump
    https://www.badcaps.net/forum/showthread.php?t=40210
    • nazrul145
      • Jan 2014
      • 337
      • BD
      Here is orginal dump.
      • lezsimply
        The Wanderer
        • 657
        • Philippines
        ok I will try this guys. thanks
        • lezsimply
          The Wanderer
          • 657
          • Philippines
          I have used dycc's bid01666 file and nazrul's upload. Both bios file made dc jack to light up but after 10 seconds it turns off. I just found out that a component is heating up. PU2 a discharge IC. I cannot seem to identify the value as I can only read P2806 on top of it and in schematic. Does anyone have datasheet for this? many many thanks.
          NOTE*
          Before I used bios file, dc jack has no light at all. But no heating component is detected.
          • khaahk
            • Dec 2013
            • 818
            • Estonia
            https://cdn.badcaps-static.com/pdfs/...0c828c330e.pdf
            • lezsimply
              The Wanderer
              • 657
              • Philippines
              Thank you very much khaahk. I'm now checking where to find it locally.
              • khaahk
                • Dec 2013
                • 818
                • Estonia
                Check the 12V LDO output for short before changing the IC.
                • lezsimply
                  The Wanderer
                  • 657
                  • Philippines
                  pc42 is shorted.
                  • lezsimply
                    The Wanderer
                    • 657
                    • Philippines
                    I replaced pc42 because its shorted. Now, light indicator on dc jack stays on and PU2 does not heat up. Now the problem is when I insert processor and press power button, dc jack light goes off then on. But when processor is remove then I press power button dc jack light stays on and system board powers up. Even fan stays on.
                    Is there a possibility that the processor is faulty? As of now I got no spare to do testing. Or I may reprogram bios using the original one? thanks guys
                    • khaahk
                      • Dec 2013
                      • 818
                      • Estonia
                      Pin 17 output?
                      Do you have oscilloscope to see if the 14V is fluctuating?
                      The capacitor was of the same size (1uF)?
                      • lezsimply
                        The Wanderer
                        • 657
                        • Philippines
                        I replaced capacitor with same value. 14v is steady not fluctuating. I'll will check pin 17 output later. I know I took down notes for all pin voltages but can't find my records. Maybe I left it somewhere.
                        • lezsimply
                          The Wanderer
                          • 657
                          • Philippines
                          pin 17 of PU2 is 30.4v what voltage should I get here around 28v?
                          • whaldsz
                            • Apr 2013
                            • 395
                            • Philippines
                            You should get 28V. it drives the gate of of PQ48 to get a normal +PWRSRC voltage.
                            • lezsimply
                              The Wanderer
                              • 657
                              • Philippines
                              thanks sir whaldsz. So there is a possiblity that this ic is at fault?
                              • lezsimply
                                The Wanderer
                                • 657
                                • Philippines
                                Just found out processor is faulty. Used i3-350m from different laptop and it worked. I just ordered from friends to replace stock procie. Hope it stays good!
                                • anandkv123
                                  • Jul 2018
                                  • 27
                                  • indiia
                                  thanks this bios worked for me
                                  • Aadi Awan
                                    • Mar 2019
                                    • 35
                                    • paksitan
                                    hey everyone.
                                    i need bios HP g6-1043sx.
                                    • lapfix
                                      • Mar 2020
                                      • 2765
                                      • my workshop
                                      Originally posted by Aadi Awan
                                      hey everyone.
                                      • Deni Miftah
                                        • Sep 2020
                                        • Indonesia
                                        thanks
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
