hi guys does anybody here have bios file for this laptop Hp G6-1030ST corei5. Board model is DA0R12MB6E0 quanta r12. Thanks in advance!
					HP g6-1030st bios dump
Re: HP g6-1030st bios dump
I have used dycc's bid01666 file and nazrul's upload. Both bios file made dc jack to light up but after 10 seconds it turns off. I just found out that a component is heating up. PU2 a discharge IC. I cannot seem to identify the value as I can only read P2806 on top of it and in schematic. Does anyone have datasheet for this? many many thanks.
NOTE*
Before I used bios file, dc jack has no light at all. But no heating component is detected.Last edited by lezsimply; 09-08-2014, 12:27 AM.Comment
I replaced pc42 because its shorted. Now, light indicator on dc jack stays on and PU2 does not heat up. Now the problem is when I insert processor and press power button, dc jack light goes off then on. But when processor is remove then I press power button dc jack light stays on and system board powers up. Even fan stays on.
Is there a possibility that the processor is faulty? As of now I got no spare to do testing. Or I may reprogram bios using the original one? thanks guys
			by AhariHi all,
I...-
			by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
			Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
			by CityminHi all,
S/N : 5RNK9FFT70...-
 - Loading...
