Thinkpad P14s Gen 4, BIOS Supervisor Password
  • badzymandiaz
    • Sep 2025
    I have a laptop that was purchased second-hand, and I am able to boot Windows on and extract the BIOS dump (ONLY the BIOS region, I was unable to dump anything else due to an FCERR I received trying to dump the other regions) and use normally. However, because the BIOS is locked with a supervisor password, I am unable to use anything else except for Windows, and it has also disabled some hardware features of the laptop itself, such as the fingerprinting module, etc. that I really do wish to use.
    I have been digging around for nearly 2 weeks trying to find any mention of the same model and generation, but received mixed results and nothing that has verifiably worked. So, I am posting on this forum in hopes of getting some help from people much more experienced than I am!
    Device: Thinkpad P14s Gen 4
    Device S/N: PF4RTEFN
    Motherboard S/N: L1HF419003T
    Thank you in advance for your help! Please reach out to me if you need any further information/clarification. For some reason I'm just not able to upload the bios dump file due to an extension error... so I used .txt instead. I think the binary contents are intact.
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1602
    • France
    Probably an nm-e972 card with a Mec1724 chip so reading the ec, no other possible solution.
    need a compatible EC programmer
    • badzymandiaz
      • Sep 2025
      Fair enough, thank you for your guidance. I will go ahead and read up on some of the Badcap guides to see what can be done, and update progress here if I ever make any.
      • badzymandiaz
        • Sep 2025
        Do you know of any particular EC programmer that can work with MEC1724? Even on the hardware support list of the SVOD 4, it doesn't explicitly mention supporting the MEC17xx series... Don't see it on the Vertyanov support list, either.
        • adamgouadma
          • Jul 2017
          • 260
          • setif
          Do SVOD 4 software supports this.The matter
          • Stefan Steff
            • Mar 2024
            • 666
            MEC1503/1723/1724 - Not supported by SVOD4
            • adamgouadma
              • Jul 2017
              • 260
              • setif
              Thank you for your honest reply.
              • azozexd
                • Sep 2019
                • 57
                • Maroc
                The svod can supporte all mec mcu but the devolopper won't update the device id off all mec chips im sure svod 4 can read all chip. like nuvoton npcx997... att first not supported but now it is supported they just add it lik new id chip on data base
                its a caustion of time in next update they will supported all mec chip
                Comme on devolloper update svod 4 i want more mony by unlocking this mcu
                • Rapadura
                  Thinkpad W500 Bios Dump
                  by Rapadura
                  Hello, can someone help me in getting a Thinkpad W500 8mb bios dump? the only ones i can find are for Thinkpad T500 and they don't work even tho they are basically the same machine. Best Regards
                  01-30-2026, 01:28 PM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • Junhijam
                  (Request) MSI PRO B660M-A DDR4 (MS-7D43 Rev 1.0) Bios Dump
                  by Junhijam
                  Hi, I'm new to all of this so I hope I'm doing correctly and not breaking any rules.
                  I need help for my MSI PRO B660M-A DDR4 motherboard BIOS dump.
                  The motherboard got bricked during BIOS update due to a power cut in my village while updating BIOS. Now the PC is not booting. Fans kept spinning and no display is coming.
                  A local technician said I need the full BIOS dump/file for this motherboard.
                  My Motherboard model is:
                  MS-7D43 REV 1.0
                  The Bios chip is:
                  MXIC
                  MX25U25673GZ4140
                  Please, if anyone has the same board...
                  05-29-2026, 03:53 AM
                • ZintosG
                  Need bios dump ThinkPad t440 model 20B7
                  by ZintosG
                  I have a ThinkPad T440 (model 20B7) that is experiencing issues with Intel ME; the BIOS does not display the ME version, and the system shuts down after 30 minutes.
                  After doing some research on various forums, I have concluded that I need to reflash the BIOS using a working BIOS dump from the same model. I would greatly appreciate it if you could help me find one....
                  05-06-2026, 11:18 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
