I need the HP zbook 17 g5 DUMP BIOS, thank you.
  • jontao
    • Jun 2019
    • 16
    • China
    I have an HP laptop, zbook 17 g5, I need an original programmer BIOS firmware, I have a friend to share, thank you very much.
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: I need the HP zbook 17 g5 DUMP BIOS, thank you.
    Whats problem your old bios?Post here someone build new
      • 20781
      He posted it already .
      https://www.badcaps.net/forum/showthread.php?t=76449
      https://www.badcaps.net/forum/showthread.php?t=77123
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Here try this just change me region i dont know is old or latest try and post results.
        • jontao
          • Jun 2019
          • 16
          • China
          I am an engineering notebook, the motherboard chipset is also QS, 涮 officially seems to be unable to start up, the boot flashes 5 times to report the motherboard failure, I need to see if the early BIOS can start, need to test.
          • alfa20fr
            • Jan 2012
            • 34
            Please need unlock zbook17g5
            thank you
              • 20781
              thank you
              Try this https://www.badcaps.net/forum/showthread.php?t=98539
              • hopkok
                • Oct 2014
                • 178
                • Slovakia
                Hi, masters.
                I am repairing, HP Zbook17 G5,
                shorted PCH was replaced, now unit start but FAN at full speed and black screen. If I remove RAM sticks, getting beeps.
                Can anyone help me to clen ME region? I tried, but no luck, still black screen. I used ME analyzer to check ME version, than ME tool to put new region in, what did I wrong? Anyway can be another problem on board, but would like to try properly cleaned ME (FAN at full speed could be ME region)
                S/N: 5CD92240D6
                Thanks for any help.
                • hardware1
                  • Sep 2021
                  • 2930
                  • N/A
                  Originally posted by hopkok
                  Hi, masters.
                  S/N: 5CD92240D6
                  Here's your New BIOS, try it and let me know.
                  all donations are welcome,
                  • hopkok
                    • Oct 2014
                    • 178
                    • Slovakia
                    Hi, I just test it, get picture and FANs spin normally. I gonna to install Windows and let you know if everything works. Many many thanks for now.
                    • hardware1
                      • Sep 2021
                      • 2930
                      • N/A
                      You're welcome.
                      • hopkok
                        • Oct 2014
                        • 178
                        • Slovakia
                        After install, everything is working well, once again, thanks for your help
                        • hardware1
                          • Sep 2021
                          • 2930
                          • N/A
                          Great.
                          • tccyo22
                            • Oct 2019
                            • 73
                            HP Zbook 17 G5 BIOS ME Clean
                            Has anyone got the firmware version 12.0.93.2331_COR_H_BA_PRD_EXTR-Y
                            I was going to clean the ME myself but I can't seem to find this version. I only have to 12.0.92.2145.
                            I've included my BIOS dump as well.
                              • 20781
                              Re: HP Zbook 17 G5 BIOS ME Clean
                              Serial number ?
                              • tccyo22
                                • Oct 2019
                                • 73
                                Originally posted by SMDFlea
                                Serial number ?
                                ah apologies
                                The serial number is 5CD9243G66
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11682
                                  ah apologies
                                  HP ZBook 17 G5 Mobile Workstation
                                  • tccyo22
                                    • Oct 2019
                                    • 73
                                    Thank you!
                                    • tccyo22
                                      • Oct 2019
                                      • 73
                                      Ok it's stuck on the BIOS screen again and no further, can get "Entering Setup..." hitting F10 but it never gets further than that.
                                      I think it may have restored the previous one from the EC? Is this a thing with Sure Start models?
                                      EDIT: Little lookup on HP's website it says it keeps a copy in the HP Endpoint Security Controller which I think has restored some of the bad parts, is there anyway I can update this controller to prevent this data mismatch?
                                      • munir100
                                        • Dec 2018
                                        • 178
                                        • uae
                                        i have hp zbook 17 g5 hag on log i try to me clean but not sceuefull hara is bios file
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • loopster
                                          Need help cleaning ME region on Zbook 17 G1 bios dump
                                          by loopster
                                          Hello guys,
                                          could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                                          Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                                          I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                                          Error 10: Failed to open with processed commands.
                                          Unable to open file: C:\Users\Elitebook...
                                          06-16-2024, 09:57 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          Today, 07:11 AM
                                        • il60
                                          zbook 17 g3 Crach During Bios update, now black screen (dump bios provided)
                                          by il60
                                          i have an zbook 17 g3, i updated the bios, but the computer crash during update
                                          now black screen
                                          may you repair my bios in order to have work bios but keep all hp information (DMI sn..)
                                          dump attached,
                                          big thank you !!!...
                                          06-09-2023, 09:51 AM
