[HELP] G712LWS BIOS capsule
  • TraJikar Mac
    • Jun 2025
    • 28
    • Turkey
    I need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
    The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
    You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
    Also, I uploaded a backup file for the bios that I extracted by using CH341A tool, but its a backup for the corrupted bios.
    How it started, and how I ended here? πŸ‘‡πŸ»
    I set an admin password for the BIOS 2 or 3 years ago, and I forgot it.
    I tried all/most available solutions on the internet but the result was always the same, nothing worked.
    Then I ended discovering this website...
    I used Aptio 5 AFU (64 WIN version) to take a backup to the BIOS (12MB), and uploaded it here so someone can help.
    Someone patched the file and tried to install it in different ways, but always failed, until I tried the following command line in windows PowerShell:
    Code:
    .\AFUWINx64.exe G712LWS_patched.rom RECOVERY /B /N REBOOT
    And the PC rebooted automatically, but never booted to Windows or BIOS again.
    So I decided to buy an SPI programmer...FAST FORWARD...
    One of the people who were trying to help me tried to recompile the BIOS file "Named as: New_BIOS.bin" (I don't know which one of the files I uploaded to that conversation that they modified), and I flashed it into the BIOS chip but didn't success/work, and I got the same black screen again.
    Extra information:
    G712LWS-EV002-Gaming
    SN: L7NRKD031177304
    CN: 778L
    MFD: 2020-07
    - Note: I don't know if capsulating would fix the problem, as this is not my field of experience, but I presume someone know enough information or has enough experience that knows how to fix it. But I asked for capsulating assuming that this would be the solution that I'm searching for...I hope.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12154
    Next time remember to backup bios with programmer, say "no" to software.
    ​https://www.badcaps.net/donate
    • TraJikar Mac
      • Jun 2025
      • 28
      • Turkey
      Thanks for trying to help, i flashed it and turned on the pc but the pc turns on for a while and then turns off, it doesn't boot and doesn't even open to the bios interface via (F2).
      I also forgot to mention that the command line below is the one that corrupted the bios, but not the one i wrote before:
      Code:
      .\AFUWINx64.exe G712LWS_patched.rom /P /B /N /REBOOT
      It was /P /B and /N
      Which means that the Main BIOS block, Boot Block, and the NVRAM region are being corrupted (maybe not all of them, idk) when I flashed the bios using the (patched) file via Aptio 5 afu win 64.
      EDIT:
      Next time I'll not even think of setting a password to the BIOS, because that was the stupidest idea I ever thought of in my life.
      EDIT2:
      The name over the BIOS chip is 25B127D, while the NewProgrammer and AsProgrammer detect different bios names, look the images below.​
      • TraJikar Mac
        • Jun 2025
        • 28
        • Turkey
        Code:
        It was /P /B and /N
        EDIT:
        EDIT2:
        There is an information that I also forgot to add to the description: The firmware image version that was installed on the BIOS before the corruption is 314 (the latest version), but not the 311 (the older version).
        I'm unsure if this information can help fix the corrupted BIOS, but I thought it would be helpful to know.
        Still, I prefer to downgrade to 311 (if possible), because the 314 decreased the maximum speed of the fans by nearly 20% (from 7300Β± RPM maximum to 6500 RPM maximum).
        • hoaca388
          Badcaps
          • Jan 2022
          • 12154
          Find hardware issues.
          • TraJikar Mac
            • Jun 2025
            • 28
            • Turkey
            I can assure you that the motherboard is working 100% and is not harmed/damaged in any way, and all other components (ram, ssd, wifi... etc).
            • TraJikar Mac
              • Jun 2025
              • 28
              • Turkey
              A guy named (Stefan Steff) uploaded an image file that fixed the BIOS and now my PC turns on.
              However, windows can't detect Nvidia GPU that is in the laptop, I'm not sure what is the reason, but I'll try to update the drivers, then reinstall windows, and if it worked I'll write another post as feedback.
              Post number Sound problems, a sign of bad caps? is the solution:
              Click here to go to the other conversation.
              • m1ch43lzm
                • Mar 2019
                • 678
                • Peru
                The laptop worked, but it couldn't detect the Nvidia graphics card, would that be because of the other chip that I erased at the beginning? Even though i reinstalled the same backup image into it later?
                Or what could be the problem, do you have any idea bro?
                From the other thread, looks like you erased the VBIOS (video BIOS, for the GPU) on the W25Q80 chip, you'll need to flash the backup you made of it
                https://www.badcaps.net/forum/troubl...53#post3656353
                Post #211, https://www.badcaps.net/filedata/fetch?id=3656354
                I checked with a hex editor and it looks like the VBIOS, it has some strings
                Code:
                E4914 SKU 30 VGA BIOS ASID: N121G712LWS
                Version 90.04.96.00.79
                Copyright (C) 1996-2019 NVIDIA Corp.
                GPU Board
                So it appears your laptop has the VBIOS on a separate chip, unlike some other laptops which have the VBIOS inside the main BIOS
                • macabook
                  πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
