ASUS G1S ask for bios pass after GPU replace.
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    i guys , got a problem on a asus G1S after change the GPU , it started asking me for bios password , i even cannot enter to windows.
    The problem is that this board have does old bios chip , MX29LV800CTTC TSSOP 8M , and the problem is that my flash machine dont have this kind of sockets , for what i've read around , it could be flashed using soldered wires to the pins , but my question is wich pins i should wire and with a 32pi n socket rom were i should solder them on that socket for i can reprogram that bios , or do you have outher solutions .
    things made :
    Reset bios , removed cmos for 12 hours , even tryed another bios frmo another board , but the same happen ...really dont know what else could be missing ,
    i will be very happy with a solution for my brother is a addictive kid to COD
    cheers
  • trebo
    • 514
    • Wales, UK
    Re: ASUS G1S ask for bios pass after GPU replace.
    check this link out, it gives you 2 default passwords for that model, and read comments
    https://www.youtube.com/watch?v=-FxyV_2Jzz4
    EDIT, also this link, https://www.badcaps.net/forum/showthread.php?t=29309
    • Luís Amaral
      • Nov 2013
      • 78
      • Portugal
      Thanks it really works
      • dj_ricoh
        • 2073
        • uk
        what pass did it work and what model?
        • Luís Amaral
          • Nov 2013
          • 78
          • Portugal
          This was the solution for me
          • trebo
            • 514
            • Wales, UK
            can we take it that you are the bro of OP (highpulse)
            glad it worked BTW
            • cyberhack
              • Feb 2013
              • 466
              • Uk
              Just got this from a site any good ? re-passwords
              • trebo
                • 514
                • Wales, UK
                thanks for that, great stuff
                here is the link for year 2008 passwords to go with it
                https://www.badcaps.net/forum/showth...746#post344746
                Last edited by trebo; 08-07-2014, 11:47 AM. Reason: put in wrong link,now corrected
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • lrouw84
                  Asus vivobook s510ua bios changed to x510un
                  by lrouw84
                  Hi there,
                  I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                  I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                  01-28-2023, 01:31 PM
