ASUS G1S ask for bios pass after GPU replace.
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    i guys , got a problem on a asus G1S after change the GPU , it started asking me for bios password , i even cannot enter to windows.
    The problem is that this board have does old bios chip , MX29LV800CTTC TSSOP 8M , and the problem is that my flash machine dont have this kind of sockets , for what i've read around , it could be flashed using soldered wires to the pins , but my question is wich pins i should wire and with a 32pi n socket rom were i should solder them on that socket for i can reprogram that bios , or do you have outher solutions .
    things made :
    Reset bios , removed cmos for 12 hours , even tryed another bios frmo another board , but the same happen ...really dont know what else could be missing ,
    i will be very happy with a solution for my brother is a addictive kid to COD
    cheers
  • trebo
    • 514
    • Wales, UK
    Re: ASUS G1S ask for bios pass after GPU replace.
    check this link out, it gives you 2 default passwords for that model, and read comments
    https://www.youtube.com/watch?v=-FxyV_2Jzz4
    EDIT, also this link, https://www.badcaps.net/forum/showthread.php?t=29309
    • Luís Amaral
      • Nov 2013
      • 78
      • Portugal
      Thanks it really works
      • dj_ricoh
        • 2073
        what pass did it work and what model?
        • Luís Amaral
          • Nov 2013
          • 78
          • Portugal
          This was the solution for me
          • trebo
            • 514
            • Wales, UK
            can we take it that you are the bro of OP (highpulse)
            glad it worked BTW
            • cyberhack
              • Feb 2013
              • 466
              • Uk
              Just got this from a site any good ? re-passwords
              • trebo
                • 514
                • Wales, UK
                thanks for that, great stuff
                here is the link for year 2008 passwords to go with it
                https://www.badcaps.net/forum/showth...746#post344746
                Last edited by trebo; 08-07-2014, 11:47 AM. Reason: put in wrong link,now corrected
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • lrouw84
                  by lrouw84
                  Hi there,
                  01-28-2023, 01:31 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
