Gigabyte G5 KD Board 6-77-NH50HP00-D04-5C does not start
  • master3112
    • Mar 2024
    • 85
    • Slovakia
    I have a Gigabyte 6-77-NH50HP00-D04-5C. The device does not start. I downloaded a BIOS file from another forum and installed it. The device started with the file, but cannot find an NVMe SSD in the BIOS. A data storage device on a SATA port or USB stick is detected. In the BIOS, the ME firmware version is 0.0.0.0. TPM is also not available. Here is my original BIOS. Can anyone help me?
  • tuyen821991
    • Oct 2024
    • 46
    • Viet Nam
    TRY BIOS
    • master3112
      • Mar 2024
      • 85
      • Slovakia
      Thank you tuyen821991. I have looked at the files. These are the files from the Gigabyte support download. I also have these, but the device does not work with these files only, because there are regions missing that have to be transferred from the original file. Not all areas are rewritten during the BIOS update. Can anyone help me which address ranges need to be transferred from the original BIOS file? Thanks to the community
      • master3112
        • Mar 2024
        • 85
        • Slovakia
        I have now found another BIOS file and tried it out. The device works with this file and the ME firmware is also available. Unfortunately, my NVMe data carrier is not recognized on either of the two ports. What could be the cause? The disk works in other devices.
          • 21523
          Please post the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
          • master3112
            • Mar 2024
            • 85
            • Slovakia
            SN22091J002450
            • master3112
              • Mar 2024
              • 85
              • Slovakia
              I have checked my defective BIOS file with ME Analyzer. The device does not start at all with the BIOS.
              Is it possible to repair such a BIOS image?​
              • tuyen821991
                • Oct 2024
                • 46
                • Viet Nam
                TRY
                • master3112
                  • Mar 2024
                  • 85
                  • Slovakia
                  Thank you tuyen821991​. The BIOS is working. The NVMe disk is recognized. Can you tell me what the problem was? thank you very much!
                  • tuyen821991
                    • Oct 2024
                    • 46
                    • Viet Nam
                    Thank you tuyen821991. The BIOS is working. The NVMe disk is recognized. Can you tell me what the problem was? thank you very much!
                    i use uefi tool to replace your me region, bios region with bios from Gigabyte.
                    i'm not good at english, i use google translate.​
                    • shahnld
                      • Nov 2019
                      • 164
                      • Netherlands
                      Good day.
                      Dear experts. Bios is needed, Gigabyte G5 KD, serial: SN22071J007613, dump is attached.
                      kind Regards
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12182
                        Originally posted by shahnld
                        Good day.
                        kind Regards
                        Gigabyte G5 KD
                        ​https://www.badcaps.net/donate
                        • BOGOSY77
                          • Aug 2018
                          • 44
                          • PITON
                          Hello friends,
                          Can you fix this bios, fan spin fast, power led blink, no display
                          Gigabyte 6-77 NH50HPOO-D04-2C
                          G5 KD
                          S/N: 1TNH50HP1500457
                          I send to you bios original. Please fix
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12182
                            Originally posted by BOGOSY77
                            Hello friends,
                            G5 KD
                            Gigabyte G5 KD
                            • BOGOSY77
                              • Aug 2018
                              • 44
                              • PITON
                              Originally posted by hoaca388
                              Gigabyte G5 KD
                              No power with this bios
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12182
                                It's the file from Gigabyte, just replace your DMI.
                                • BOGOSY77
                                  • Aug 2018
                                  • 44
                                  • PITON
                                  Can you do if for me,
                                  • tuyen821991
                                    • Oct 2024
                                    • 46
                                    • Viet Nam
                                    try
                                    • microcba
                                      • Sep 2022
                                      • 3
                                      • Argentina
                                      Hola tendrĂ­a BIOS reparada de la Gigabyte G5 KD S/N : SN21521J004544 Muchas Gracias.
                                      Hello, I would like to have the BIOS repaired for the Gigabyte G5 KD S/N: SN21521J004544. Thank you very much.
                                      in English please...
                                      • peste
                                        • Dec 2016
                                        • 13258
                                        • ROMANIA
                                        post full name and model, motherboard model,post the contents of the bios chip even if it is corrupted..etc...
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
