Gigabyte G5 KD Board 6-77-NH50HP00-D04-5C does not start
  • master3112
    • Mar 2024
    • 73
    • Slovakia
    I have a Gigabyte 6-77-NH50HP00-D04-5C. The device does not start. I downloaded a BIOS file from another forum and installed it. The device started with the file, but cannot find an NVMe SSD in the BIOS. A data storage device on a SATA port or USB stick is detected. In the BIOS, the ME firmware version is 0.0.0.0. TPM is also not available. Here is my original BIOS. Can anyone help me?
  • tuyen821991
    • Oct 2024
    • 44
    • Viet Nam
    TRY BIOS
    • master3112
      • Mar 2024
      • 73
      • Slovakia
      Thank you tuyen821991. I have looked at the files. These are the files from the Gigabyte support download. I also have these, but the device does not work with these files only, because there are regions missing that have to be transferred from the original file. Not all areas are rewritten during the BIOS update. Can anyone help me which address ranges need to be transferred from the original BIOS file? Thanks to the community
      • master3112
        • Mar 2024
        • 73
        • Slovakia
        I have now found another BIOS file and tried it out. The device works with this file and the ME firmware is also available. Unfortunately, my NVMe data carrier is not recognized on either of the two ports. What could be the cause? The disk works in other devices.
          • 20807
          Please post the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
          • master3112
            • Mar 2024
            • 73
            • Slovakia
            SN22091J002450
            • master3112
              • Mar 2024
              • 73
              • Slovakia
              I have checked my defective BIOS file with ME Analyzer. The device does not start at all with the BIOS.
              Is it possible to repair such a BIOS image?​
              • tuyen821991
                • Oct 2024
                • 44
                • Viet Nam
                TRY
                • master3112
                  • Mar 2024
                  • 73
                  • Slovakia
                  Thank you tuyen821991​. The BIOS is working. The NVMe disk is recognized. Can you tell me what the problem was? thank you very much!
                  • tuyen821991
                    • Oct 2024
                    • 44
                    • Viet Nam
                    Thank you tuyen821991. The BIOS is working. The NVMe disk is recognized. Can you tell me what the problem was? thank you very much!
                    i use uefi tool to replace your me region, bios region with bios from Gigabyte.
                    i'm not good at english, i use google translate.​
                    • shahnld
                      • Nov 2019
                      • 159
                      • Netherlands
                      Good day.
                      Dear experts. Bios is needed, Gigabyte G5 KD, serial: SN22071J007613, dump is attached.
                      kind Regards
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11711
                        Originally posted by shahnld
                        Good day.
                        kind Regards
                        Gigabyte G5 KD
                        • BOGOSY77
                          • Aug 2018
                          • 20
                          • PITON
                          Hello friends,
                          Can you fix this bios, fan spin fast, power led blink, no display
                          Gigabyte 6-77 NH50HPOO-D04-2C
                          G5 KD
                          S/N: 1TNH50HP1500457
                          I send to you bios original. Please fix
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11711
                            Originally posted by BOGOSY77
                            Hello friends,
                            G5 KD
                            Gigabyte G5 KD
                            • BOGOSY77
                              • Aug 2018
                              • 20
                              • PITON
                              Originally posted by hoaca388
                              Gigabyte G5 KD
                              No power with this bios
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11711
                                It's the file from Gigabyte, just replace your DMI.
                                • BOGOSY77
                                  • Aug 2018
                                  • 20
                                  • PITON
                                  Can you do if for me,
                                  • tuyen821991
                                    • Oct 2024
                                    • 44
                                    • Viet Nam
                                    try
                                    • microcba
                                      • Sep 2022
                                      • 3
                                      • Argentina
                                      Hola tendría BIOS reparada de la Gigabyte G5 KD S/N : SN21521J004544 Muchas Gracias.
                                      Hello, I would like to have the BIOS repaired for the Gigabyte G5 KD S/N: SN21521J004544. Thank you very much.
                                      in English please...
                                      • peste
                                        • Dec 2016
                                        • 12748
                                        • ROMANIA
                                        post full name and model, motherboard model,post the contents of the bios chip even if it is corrupted..etc...
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
                                        • maanee11
                                          Help to get Lenovo BIOS bin file for Thinkpad T560
                                          by maanee11
                                          Hello Everyone,
                                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                          05-15-2022, 11:59 AM
                                        • Sebastian Codrean
                                          BIOS file for ASUS F542UN laptop
                                          by Sebastian Codrean
                                          Hello to all of you! I need help with a BIOS file.
                                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                          02-20-2025, 10:25 AM
