Gigabyte G5 KD Board 6-77-NH50HP00-D04-5C does not start
  • microcba
    • Sep 2022
    • 6
    • Argentina
    Hello, I would like a repaired BIOS for the Gigabyte G5 KD S/N: SN21521J004544. Thank you very much.
    Hi, I would like you to repair the BIOS for my Gigabyte G5 KD S/N: SN21521J004544. Thank you very much.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12403
      G5_KD
      • BOGOSY77
        • Aug 2018
        • 59
        • PITON
        Originally posted by tuyen821991
        try
        Thank you so much all good
        • BOGOSY77
          • Aug 2018
          • 59
          • PITON
          Originally posted by hoaca388
          G5_KD
          Thank you, good.
          • vougheart
            • Jul 2020
            • 65
            • philippines
            i have my gigabyte g5 kd
            s/n: 1TNH50HP00002113672
            P/N: 6-7-NH50P00-D04-5C
            it has display but 5 to 10sec keeps beeping countinuesly then shutdow i tried every bios here but still the same
            ive already replaced 2 fans that not spinning but the beeps still there
            2 fans power at max when i turn on
            can anyone help me with bios?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12403
              #26
              Find hardware problem.
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • maanee11
                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                by maanee11
                Hello Everyone,
                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                In the website, you can only see specs etc.
                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                11-08-2025, 04:08 AM
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
