Lenovo X1 Yoga Gen5 Full Bios chip dump request.
  • Rdd KEuns
    • Mar 2025
    • 5
    • japan
    Hello, My lenovo x1 yoga gen5 laptop has been unstable and sometime freezes. After downgrading the bios i was normal for a moment but when back to being unstable.
    If anyone has an working bios please share it.
    Laptop lenovo x1 yoga gen5. serial number PF-2MSZ9Q. Type number 20UC-S2410N. Motherboard model number GX4A0/GY650 NM-C881 Rev1.0. Bios chip GD25B256DYIG
    Last edited by Rdd KEuns; 03-21-2025, 06:30 AM. Reason: Forgot to upload laptop bios
  • Rdd KEuns
    • Mar 2025
    • 5
    • japan
    I suspect the intel ME is corrupted and is bad.
    • danito
      • Jun 2016
      • 1052
      • Romania
      post the original bios of the laptop even if it is corrupted,the motherboard model, etc.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12182
        Where's your dump ?
        • Rdd KEuns
          • Mar 2025
          • 5
          • japan
          uploaded the bios
          • hoaca388
            Badcaps
            • Jan 2022
            • 12182
            X1 Yoga 5th Gen Laptop (ThinkPad) - Type 20UC
            • Rdd KEuns
              • Mar 2025
              • 5
              • japan
              I'm stuck on trying to flash onto my new bios chip. I can read it check do check sum or what not, But the moment i try to flash onto it. The bios programmer freezes. I think the chip has write protection? How do i remove this protection?
              I tried to do "Unprotect" But i doesn't change anything
              • Rdd KEuns
                • Mar 2025
                • 5
                • japan
                Flashed it to the old chip and was able to write to it. But installing onto the motherboard no light or power. Just plugging in the power gives three flashes on the power LED but after that non anymore.
                • vicmark63
                  • May 2023
                  • 10
                  Hallo everyone, If anyone could help with correcting my BIOS dump - the device starts without picture, all voltages are correct.
                  Laptop : Lenovo X1 Yoga Gen5, Type : 20UC-S5A501, S/N : PF2JCS9B, Motherboard : GX4A0/GYG50 NM-C881 Rev. 1.0
                  Thanx in advance
                  • AHmad_Salal
                    Need BIOS Dump/ROM for Lenovo Thinkstation p500
                    by AHmad_Salal
                    Hello all,
                    I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                    11-28-2023, 05:28 AM
                  • AYsys
                    Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
                    by AYsys
                    Hello dear forum members,
                    I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
                    I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
                    Nothing was flashed here — the BIOS was only backed up.
                    I created the backup using a CH341A Black programmer and NeoProgrammer....
                    09-13-2025, 11:05 AM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • hyperwood
                    [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                    by hyperwood
                    I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                    The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                    I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                    ✅ What I need:
                    • A working 2MB BIOS dump
                    • Matching NM-E471 Rev. 2.0, e.g. JY575
                    06-25-2025, 02:28 PM
                  • HotSaladMan
                    Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                    by HotSaladMan
                    *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                    Model : Lenovo ThinkBook 14S Yoga ITL
                    S/N : MP28JT19
                    MFG Date : 2022/02/09
                    Factory ID PRC4
                    MO : MPNXB26080FX
                    MTM : 20WE001US
                    MODULE FCC ID : PD9AX201NG
                    IC : 1000M-AX201NG
                    BOARD INFO
                    FLV34 LA-KO51P
                    REV : 1B 2020-08-24
                    Bit of Info
                    Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                    chip id, so i would always uncheck the id check, so it would bypass the error
                    i did in fact make...
                    11-07-2024, 07:46 AM
