Dell 8FC8 Patcher
  • Firechixh
    • Aug 2025
    • United Kingdom
    #101
    rex98 please could you re-upload the source code and video tutorial since, for some reason, when clicked it says "invalid file specified".
    • f@brice
      • Nov 2019
      • 78
      • France
      #102
      https://www.badcaps.net/forum/troubl...00#post3683800
      • Firechixh
        • Aug 2025
        • United Kingdom
        #103
        For a dell latitude 5420 what is the best way to r/w to the BIOS chip since it does not seem like a traditional clip can do the job. Should I sand down the ends of the clip so the metal can touch or is there some other method (preferably without unsoldering) that can allow me to r/w to the chip. I have a CH341A programmer and clip but the BIOS chip (windbond 25R256JVEN) seems to be surface installed.
        • peste
          • Dec 2016
          • 13653
          • ROMANIA
          #104
          The bios chip must be unsoldered from the board before writing or reading..
          do not use the clip, you may have errors..if you do not have anything to unsolder it with,
          solder wires between the programmer and the bios chip..
          here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
          You can also use an adapter for these chips.
          • vamota
            • Sep 2021
            • 9
            Many thanks for this great little tool : thanks to this , I bought my first ever T48 EEPROM programmer, and managed to re-program my Dell Latitude 7400 ( in-circuit , as a bonus! ) and get it into Manufacturing mode to remove the system password. Very pleased with myself .. thanks again
            • Bilal@pc
              • Jun 2021
              • 44
              • Algeria
              #106
              THINKS FOR ALL
              • spacez
                • Nov 2023
                • 69
                • FR
                #107
                PLEASE UNLOCK MY XPS 15 9520
                ST : 8LGSKR3
                • f@brice
                  • Nov 2019
                  • 78
                  • France
                  #108
                  Try this and report result, please
                    • 21960
                    ST : 8LGSKR3
                    Didn`t you try using the patcher yourself ? ,was there some error using it ?
                    • spacez
                      • Nov 2023
                      • 69
                      • FR
                      #110
                      thanks working
                      • spacez
                        • Nov 2023
                        • 69
                        • FR
                        #111
                        tryed old method and patcher . not woring
                        • Caineavenue
                          • Sep 2025
                          I keep getting the error of " Hex Pattern Not Found" Not sure what I'm doing wrong. I am using the Xgecu T48 Pro with the program Xgpro. Any suggestions?
                          EDIT: I am also using a BIOs clip. Not sure if that information is relevant
                          • monitorjoe
                            • Sep 2025
                            I just wanted to say thank you for this patcher. It worked perfectly after clipping and dumping the BIOS of a Dell Optiplex 3000 micro (12th gen) with NeoProgrammer which was the first one I could find that said it had support for the chip. After hashing a few dumps to make sure they were coming out identical, I patched one, wrote it back, and then the device booted into factory mode and let me set the service tag. Importantly the admin password was no longer present.
                            • f@brice
                              • Nov 2019
                              • 78
                              • France
                              #114
                              what device did you use to read the chip?
                              • sadpandaa92
                                • May 2025
                                • united kingdom
                                #115
                                I'm getting the same if you have a solution would be great would prefer not to have to fix this if someone else has already done it.
                                Board: northbay non-TBT MB A00 18827-1 P3HJY$CA
                                Chip: w25q128jvsq
                                Dell Latitude 5300
                                Used a ch341 black, used dual read to compare hex, output is from neoprogramer saved the bin directly out of the app. Checked in hxd no headers or any sort of modification from what i see in neo.
                                  • 21960
                                  Chip: w25q128jvsq
                                  Dell Latitude 5300
                                  The 5300 has a single 32MB chip or it`s split across two chips 8 + 16MB .Look for the 8MB chip ,patch that.
                                  • monitorjoe
                                    • Sep 2025
                                    https://www.amazon.com/dp/B07R5LPTYM "SOIC8 SOP8 Flash Chip IC Test Clips Socket Adpter Programmer BIOS + CH341A 24 25 Series for EEPROM Flash BIOS USB Programmer Module (Double Clip+ USB)"
                                    In the 3000 micro case it seemed to be a Macronix MX25L12872F which was right by the battery on the board. Other than having to fiddle with the clip a couple times to get it on solidly it worked well.
                                    • SudoBash
                                      • Sep 2025
                                      Hey everyone, I'm new to the forums and just needed some help on an Optiplex 7090 8FC8.
                                      I've tried various patchers and keep getting:
                                      Searching for Intel signature...
                                      Intel signature found at offset 0x10
                                      Checking for first pattern...
                                      Almost done! Checking second pattern...
                                      Patching failed: No patterns found
                                      I keep getting no patterns found, but I dumped my rom with chipsec_util spi dump and chipsec_util spi read after signing the helper kernel driver to get chipsec fully running.
                                      8FC8 seems highly locked down, but there has to be a process for in system programming, I believe. I can flash the BIOS region and I have a TON of info and data on the system, flash, regions and even extracted parts of the firmware.
                                      Here is the method I used to do all this on the system that is locked:
                                      Install Ubuntu on an unlocked system that has secure boot enabled and put it in the locked system once installed and bootable.
                                      Boot Ubuntu, update, upgrade, install various tools and utilities as well as build-essentials.
                                      Install and setup chipsec, creating the kernel helper module.
                                      Create a key for signing and register it, reboot, enroll MOK and boot back to Ubuntu.
                                      Sign the kernel module and install it.
                                      Run chipsec and see how secure 8FC8 actually is for yourself.
                                      Attack S3 Boot Scripts to gain SMI/SMM write permission and SPI write access?
                                      What are the patterns the patchers are looking for?
                                      I'm able to write to BIOS region, but need to know where to clear the password. I don't have access to write to ME or other regions through internal in-system programming, though.
                                      Thanks!
                                      Here is some of what I've collected so far:
                                      • SomeDude12
                                        • Sep 2025
                                        Fixed a Precision 3640 with this great little tool. Thank you!
                                        • petrov7875
                                          • Oct 2023
                                          • 3
                                          • bulgaria
                                          #120
                                          Tested and worked on Dell 5510 , everything is ok . Thank you !!!
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Dell 8FC8 Bios Password Patcher
                                            by SMDFlea
                                              DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
                                              The unlock scripts given here are for personal use only, ie. you accidentally set a password on
                                              your own machine,you forgot the password you set a long time ago or you mistyped the password
                                              when setting it and cannot get in again.
                                              DISCLAIMER: THE SCRIPTS
                                            11-03-2023, 06:02 AM
                                          • al_b0sni
                                            Dell Optiplex 5000 8fc8 with chip W25Q128JVSN
                                            by al_b0sni
                                            Hey, i bought a Dell Optiplex 5000 8fc8 with chip W25Q128JVSN.
                                            I also used the CH341A programmer but my usb cable (i didnt attach it directly into the pc, i used a cable between) was corrupted. So i made a dump. Then i removed the password but unfortunately the dump had a loose contact so it was corrupted. And i've also overwrited the chip and now i dont have any dump anymore.
                                            Can someone help me? I am stuck since hours and i cannot find any bin file anywhere.
                                            I tried to extract the EXE for BIOS installation from dell and also the rcv file but i didn't manage to do that....
                                            06-18-2025, 03:42 PM
                                          • dr_crx
                                            Dell 7740 Bios locked J3JSD43-8FC8
                                            by dr_crx
                                            Hello i need help please
                                            i have DELL 7740 ST: J3JSD43-8FC8
                                            i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                            anyone can help to show its location on motherboard please.
                                            i attached the results file the IC i read is : winbond 25q80dvsig
                                            i don't know if its the needed bios or another bios on the motherboard.
                                            thank you in advanced for your help...
                                            07-11-2025, 12:22 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
