Keyboard RGB issue - Dell g15 UEL 2 bios dump
  • slade1
    • Aug 2023
    • 11
    • N/A
    After a bios downgrade, the keyboard's RGB stopped working, now in the device manager the STM32 Bootloader device appears, I discovered that it is the rgb microcontroller, I believe that (STM32 bootloader) is because it does not identify the bios file (UEL2)
    Does anyone have the BIOS dump (UEL 2) of the Dell G15? It is responsible for the RGB keyboard.
    Click image for larger version  Name:	1.jpg Views:	0 Size:	215.7 KB ID:	3504532
    • 20907
    Post the full laptop model number and Type and post the service tag
    • slade1
      • Aug 2023
      • 11
      • N/A
      Hi, service tag: 7NV0QH3, mobo: Dell G15 5510 LA-K661P
      • TuanTongbadcaps
        • Mar 2023
        • 64
        • VietNam
        You need to program UEL1, programming UEL2 doesn't work. Have you tried with a new BIOS?
        • slade1
          • Aug 2023
          • 11
          • N/A
          I just updated the bios, but without success.
          in the bios update files, there is nothing related to the ELC firmware
Name:	Captura de tela 2024-11-12 234443.png
          • TuanTongbadcaps
            • Mar 2023
            • 64
            • VietNam
            You need to get it from another active device, or from the donor table. That's what I know.
            • NotEnough
              Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
              by NotEnough
              I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
              What I've Tried So Far:
              • Reseated the cables.
              • Reinstalled AWCC and AlienFX services.
              • Attempted BIOS downgrade but no improvement.
              • Inspected ribbon cables for damage.
              • Explored the possibility of BIOS or
              10-19-2024, 01:34 AM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • Kjell
              Samsung Series 9 - BIOS issue
              by Kjell
              After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
              Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
              08-01-2025, 09:15 AM
            • gizaha
              by gizaha
              02-13-2024, 07:18 AM
