Keyboard RGB issue - Dell g15 UEL 2 bios dump
  • slade1
    • Aug 2023
    • 11
    • N/A
    After a bios downgrade, the keyboard's RGB stopped working, now in the device manager the STM32 Bootloader device appears, I discovered that it is the rgb microcontroller, I believe that (STM32 bootloader) is because it does not identify the bios file (UEL2)
    Does anyone have the BIOS dump (UEL 2) of the Dell G15? It is responsible for the RGB keyboard.
    Click image for larger version  Name:	1.jpg Views:	0 Size:	215.7 KB ID:	3504532
    • 22286
    Post the full laptop model number and Type and post the service tag
    • slade1
      • Aug 2023
      • 11
      • N/A
      Hi, service tag: 7NV0QH3, mobo: Dell G15 5510 LA-K661P
      • TuanTongbadcaps
        • Mar 2023
        • 64
        • VietNam
        You need to program UEL1, programming UEL2 doesn't work. Have you tried with a new BIOS?
        • slade1
          • Aug 2023
          • 11
          • N/A
          I just updated the bios, but without success.
          in the bios update files, there is nothing related to the ELC firmware
Name:	Captura de tela 2024-11-12 234443.png
          • TuanTongbadcaps
            • Mar 2023
            • 64
            • VietNam
            You need to get it from another active device, or from the donor table. That's what I know.
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • NotEnough
              Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
              by NotEnough
              I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
              What I've Tried So Far:
              • Reseated the cables.
              • Reinstalled AWCC and AlienFX services.
              • Attempted BIOS downgrade but no improvement.
              • Inspected ribbon cables for damage.
              • Explored the possibility of BIOS or
              10-19-2024, 01:34 AM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • capoplays
              Help with BIOS update on Dell G15 5515 after chip replacement
              by capoplays
              Hey everyone,
              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
              When I check the BIOS using the F12 menu Flash...
              10-24-2025, 06:53 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
