Inspiron 16 5625 bios
  • trepachka
    • Oct 2022
    • 429
    I have this Dell Inspiron 16 5625 which is a 16-inch version of Inspiron 14 5425.
    Upon powering on, computer keyboard lights up, the fans begin to spin and the cpu gets hot accordingly but no video. I suspect corrupted BIOS. The original BIOS file is attached.
    Could someone, please fix it or perhaps I can try one of the bin files on this thread?
    Inspiron 16 5625
    Service Tag# BFTHJL3
    Thank you
  • shiyab
    • Sep 2023
    • 1478
    • india
    Inspiron 16 5625
    Thank you
    hi try new file
    • hoaca388
      Badcaps
      • Jan 2022
      • 11741
      Inspiron 16 5625
      Thank you
      Inspiron 16 5625
      Service Tag: BFTHJL3
      • trepachka
        • Oct 2022
        • 429
        I posted my response on the original board. I applied the new bin and the computer is working now. Thank you.
        • Rickkap
          • Aug 2015
          • 130
          Is it possible for someone to change the service tag for me? I've tried the bios in post 3 and it's working fine but the customer wants the same service tag as before.
          Service tag needed is CC20SL3
          Thank you​
          • LBTT1121
            • Nov 2024
            • 540
            • Việt Nam
            Thank you​
            try
            • Rickkap
              • Aug 2015
              • 130
              Thank you
              • nguyenhuuducntu
                • Apr 2025
                • 35
                • Japan
                Hello everyone! Can someone help me? My Dell Inspiron 16 5625 laptop when turned on the light is on, the fan is spinning but the screen is not on. I tried to download the Bios with Service Tag BFTHJL3, unlike my machine above, it starts but the Camera is not recognized. Can someone fix the original Bios file for me?
                ST: 8HWWTL3
                Reg Model: P117F
                Reg Type No: P117F005​
                • bbanana
                  Father Land
                  • Oct 2021
                  • 164
                  • Vietnam
                  ST: 8HWWTL3
                  Reg Model: P117F
                  try
                  • nguyenhuuducntu
                    • Apr 2025
                    • 35
                    • Japan
                    Originally posted by bbanana
                    try
                    thank you so much! i am at work now, so i will try it tonight and report back to you!
                    • nguyenhuuducntu
                      • Apr 2025
                      • 35
                      • Japan
                      hi, thanks for your help, however when i finished updating, entered the correct ServiceTag but still can't find the camera, the fan spins abnormally strong. Can you help me again?
                      • bbanana
                        Father Land
                        • Oct 2021
                        • 164
                        • Vietnam
                        other version of your model, try and good luck
                        • nguyenhuuducntu
                          • Apr 2025
                          • 35
                          • Japan
                          Hi, I just tried the file you just uploaded, but everything is still the same. Is it possible that I am doing it wrong?
                          • nguyenhuuducntu
                            • Apr 2025
                            • 35
                            • Japan
                            After updating the bios, do I need to do anything else?
                            • bbanana
                              Father Land
                              • Oct 2021
                              • 164
                              • Vietnam
                              no need do anything, just write your servicetag and save, press Alt+F if in manufacturing mode. that's bios from official for your model, if camera didnt show you should check connector, cabble, camera,...
                              • nguyenhuuducntu
                                • Apr 2025
                                • 35
                                • Japan
                                Mình đã tháo màn hình ra, kiểm tra camera, máy còn nguyên zin, các cáp kết nối sạch sẽ và chắc chắn, khó có thể là lỗi phần cứng. Sau khi cập nhật bios xong thì máy hiện lên logo xong hiện lên một dòng gì trên đầu màn hình khoảng 1 giây giống như kiểu manufactoring Fn + X gì ấy xong vào win luôn
                                • lapfix
                                  • Mar 2020
                                  • 2729
                                  • my workshop
                                  ENGLISH
                                  • nguyenhuuducntu
                                    • Apr 2025
                                    • 35
                                    • Japan
                                    I removed the screen, checked the camera, the device is still original, the connection cables are clean and sturdy, it is unlikely to be a hardware error. After updating the bios, the device shows the logo and then a line appears at the top of the screen for about 1 second like manufactoring Fn + X or something and then enters Windows.
                                    • bbanana
                                      Father Land
                                      • Oct 2021
                                      • 164
                                      • Vietnam
                                      This model use AMD CPU, so easier than Intel CPU (repair old BIOS)
                                      so, the BIOS from Dell Support is good with servicetag, or you can try to downgrade the BIOS version to check.
                                      sometimes hardware can issue from BIOS update…
                                      • nguyenhuuducntu
                                        • Apr 2025
                                        • 35
                                        • Japan
                                        I also thought about downgrading Bios, but when I downgraded using USB, the current bios locked it and did not allow downgrading. I do not have the bin file of the previous bios version! Can you help me?
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • zlr8r
                                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                          by zlr8r
                                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                          cheers
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                          Attached;
                                          1. My saved bios using a programmer
                                          2. Dells Bios updater .exe (v1.16)
                                          3. Dells Bios recovery file
                                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                          5. Image of ME...
                                          12-18-2023, 03:08 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • dr.thodt
                                          Dell Inspiron 14 5425 bios needed
                                          by dr.thodt
                                          I have a Dell Inspiron P157G004 here which does everything except turn on the screen. I see a lot of activity on the bios chip's pin 5 but just a high signal on pin 2. Therefore I suspect the content of the chip.
                                          Could somebody take a look at the attached dump?
                                          The info from the sticker:
                                          Reg Model: P157G
                                          Reg Type No.: P157G004
                                          ZU10247-21009
                                          R-R-E2K-P157G004
                                          DP/N: CC6TY A00
                                          ST: JF64DS3
                                          EX: 42276139203
                                          Thanks in advance...
                                          06-25-2024, 07:37 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
