Bios Asus X513EQN
  • mihhh
    • Nov 2021
    • 13
    • ukraine
    Bios Asus X513EQN
    hi guys need bios for asus K513E
    motherboard
    sn:69N1C5M22B14
    • 20848
    Originally posted by mihhh
    hi gays need bios for asus K513E
    motherboard
    sn:69N1C5M22B14
    bios
    • mihhh
      • Nov 2021
      • 13
      • ukraine
      everything works thanks 👍
      • mihhh
        • Nov 2021
        • 13
        • ukraine
        there is a problem at startup. after pressing the power button, start after 30 seconds
          • 20848
          Extract the attached file to a folder, open a command line and change to the folder directory, then run the command: fptw64 -greset
          Reboot and see if it has made any difference.
          • mihhh
            • Nov 2021
            • 13
            • ukraine
            I did and
            from adapter start is normal. on the battery start 30 seconds​
              • 20848
              I did and
              I doubt its a bios problem. Is it running ok on the battery after it boots up. If performance is slow after booting from battery check the power plans, run diagnostics on the battery https://www.asus.com/support/faq/1045716/ .
              • mihhh
                • Nov 2021
                • 13
                • ukraine
                i flash this me region 15.0.35.1951_CON_LP_B_PRD_EXTR_4D29C2A9
                and its ok.
                work normal.
                • mihhh
                  • Nov 2021
                  • 13
                  • ukraine
                  work bios
                  • glovecaps
                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                    by glovecaps
                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                    11-25-2024, 04:23 PM
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • oragano
                    ASUS ex-b250-V7 motherboard bios corrupted - by me
                    by oragano
                    hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                    So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                    i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                    10-17-2024, 02:53 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • eastcoastcomputing
                    Please help Asus ROG G713QY-K4005T (SN: MANRKD03332840C), motherboard ref: G713-6050A3254002-MB-A01 (A1) Bios
                    by eastcoastcomputing
                    Hi there,
                    I have an Asus G713QY that won't boot. The machine fire up to a black screen, no post but everything seems to check out on the board. I believe the motherboard needs the bios reloaded but I can't find the bios file. I've looked on the Asus website but what is available for download is the .exe to run in windows (which won't help). I've tried to unzip it but can't see the bios file that I need. Can anyone share the bios file for an Asus ROG G713QY-K4005T (SN: MANRKD03332840C), motherboard ref: G713-6050A3254002-MB-A01 (A1). Thanks
                    02-21-2024, 04:32 AM
