Bios Asus X513EQN
  • mihhh
    • Nov 2021
    • 13
    • ukraine
    Bios Asus X513EQN
    hi guys need bios for asus K513E
    motherboard
    sn:69N1C5M22B14
    • 22264
    Originally posted by mihhh
    hi gays need bios for asus K513E
    motherboard
    sn:69N1C5M22B14
    bios
    • mihhh
      • Nov 2021
      • 13
      • ukraine
      everything works thanks 👍
      • mihhh
        • Nov 2021
        • 13
        • ukraine
        there is a problem at startup. after pressing the power button, start after 30 seconds
          • 22264
          Extract the attached file to a folder, open a command line and change to the folder directory, then run the command: fptw64 -greset
          Reboot and see if it has made any difference.
          • mihhh
            • Nov 2021
            • 13
            • ukraine
            I did and
            from adapter start is normal. on the battery start 30 seconds​
              • 22264
              I did and
              I doubt its a bios problem. Is it running ok on the battery after it boots up. If performance is slow after booting from battery check the power plans, run diagnostics on the battery https://www.asus.com/support/faq/1045716/ .
              • mihhh
                • Nov 2021
                • 13
                • ukraine
                i flash this me region 15.0.35.1951_CON_LP_B_PRD_EXTR_4D29C2A9
                and its ok.
                work normal.
                • mihhh
                  • Nov 2021
                  • 13
                  • ukraine
                  work bios
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • grimacelord
                    by grimacelord
                    07-10-2025, 02:52 PM
                  • TOMÁŠ
                    Asus vivobook k513e bios request
                    by TOMÁŠ
                    Device:laptop
                    Brand: asus
                    Model: vivobook k513e
                    Motherboard: x513ea
                    SN: M5N0CV20H570216
                    Hi, I have problem with asus vivobook k513e. Came to with no pictures I found dump and flashed in to it, was working but did not see in bios ssd, so found another bios file now I can see ssd but laptop lagging evenin bios, also i opened hex editor and change serial number, maybe i did something?
                    sometimes not usable so i think its need beter bios, maybe fixing original or brand new but i don't know how to make it. Please can someone help me with this. Thanks for your help...
                    11-14-2024, 05:49 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
