bricked bios on thinkbook 15 g2 itl
  • shiyab
    • Sep 2023
    • 1646
    • india
    Originally posted by huss584
    Need Help Please any Update ?
    hi try both file flash
    • huss584
      Hussein
      • Apr 2020
      • 230
      • Palestine
      Hello
      I reprogram the BIOS file but the power Led Light for 5 second continuously
      • shiyab
        • Sep 2023
        • 1646
        • india
        Hello
        flash both
        • huss584
          Hussein
          • Apr 2020
          • 230
          • Palestine
          Originally posted by shiyab
          flash both
          I do that and I use another BIOS Chip working 100% Same Problem
          • shiyab
            • Sep 2023
            • 1646
            • india
            bord issu
            • duder
              • Oct 2013
              • 41
              • canada
              #26
              Lenovo Thinkbook 15 G2 ITL
              S/N MP231LXP
              MTM 20VE004HUS
              Board LA-K052P
              Would someone be kind enough to take a look at my BIOS? Computer has the usual problem of no display with caps + esc + num lock lights. I have enclosed both files. I extracted the one from lenovo, but could not proceed from there. Ended up with DOSFLV34_QS.bin.
              • m1ch43lzm
                • Mar 2019
                • 1032
                • Peru
                #27
                Try BIOS extracted from Lenovo website, DMI inserted
                ThinkBook 15 G2 ITL Laptop - Type 20VE
                S/N MP231LXP
                MTM 20VE004HUS
                ​BIOS ver. F8CN59WW
                DMI 20000-207FF
                Win key 92000-9203F
                If that doesn't work, check for hardware problem, in this forum quite a few with same issue (also on the ThinkBook 14 G2 ITL), some even died after reading BIOS chip from working laptop to remove password, probably cracked solder balls under CPU
                • duder
                  • Oct 2013
                  • 41
                  • canada
                  #28
                  S/N MP231LXP
                  MTM 20VE004HUS
                  BIOS ver. F8CN59WW
                  DMI 20000-207FF
                  Win key 92000-9203F
                  Thank you for the quick response and help. Unfortunately, that did not work. It gave me different symptoms - just powers on and off repeatedly. No fan, caps lock, num lock or escape lights. So I flashed the original backups back to the chips and did a read and compare. Now I have the same symptoms as the files you provided me with.
                  I think you may be right about cpu problem. The sequence of events as described to me that led up to this were bizarre. I was told that he shut it down one day and the next time he powered it up, he was asked for bitlocker key. He went to his account and retrieved the key, entered it and the machine worked for about 15 minutes and died. Then was stuck with the flashing lights.
                  Modern electronics these days seems to be mostly junk!
                  • oceks
                    • Feb 2017
                    • 11
                    • tukey
                    #29
                    I need a BIOS file. The computer powers on, but there is no display. It seems to start up normally, but no video output appears.
                    The 1.8V, 3.3V, and 5V rails are normal. However, the CPU and GPU voltages are missing. After about 10 seconds, the 3.3V and 1.8V lines shut down, and the fan starts spinning at high speed.
                    I suspect a BIOS-related issue. I would appreciate your help.
                    Device model: ThinBook 15 G2 ITL
                    S/N: MP1YNG5C
                    Mainboard : FLV35 LA-K052P REV :1.0
                      SMDFlea commented
                      Editing a comment
                      Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
                      Your other post has been deleted, please post only once in one thread and wait for a reply, read the rules https://www.badcaps.net/forum/troubl...before-posting
                  • m1ch43lzm
                    • Mar 2019
                    • 1032
                    • Peru
                    #30
                    Try, flash both chips
                    S/N MP1YNG5C
                    MTM 20VE0072TX
                    BIOS ver. F8CN59WW
                    DMI 20000-207FF
                    Win key 92000-9203F
                    • oceks
                      • Feb 2017
                      • 11
                      • tukey
                      #31
                      S/N MP1YNG5C
                      MTM 20VE0072TX
                      BIOS ver. F8CN59WW
                      DMI 20000-207FF
                      Win key 92000-9203F
                      Thanks, the computer worked. Sometimes it shuts down as soon as the image appears on the screen, sometimes it shuts down after the operating system starts, and then it restarts, but the reset cycle occurs randomly.
                      • oceks
                        • Feb 2017
                        • 11
                        • tukey
                        #32
                        [QUOTE=oceks;n3754904]
                        • to5it0
                          by to5it0
                          10-24-2025, 01:35 AM
                        • Fr33man
                          BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                          by Fr33man
                          I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                          *Novo button power on
                          *Disconnected internal battery...
                          09-23-2024, 01:16 PM
                        • studdy05
                          Bricked HP Probook 450 G7 Bios questions
                          by studdy05
                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                          Ive got...
                          07-08-2025, 09:24 PM
                        • pcwhiz24
                          Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                          by pcwhiz24
                          Model: Lenovo IdeaPad 3 14ADA05 81W0
                          S/N: PF2BZS7D
                          I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                          I already have a CH341A programmer...
                          04-07-2025, 07:10 PM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
