bricked bios on thinkbook 15 g2 itl
  • Magician1981
    • Sep 2024
    • 16
    • netherlands
    Greetings,
    I kindly request assistance with the following. My lenovo thinkbook 15 g2 itl has the following symptoms:
    - blank screen
    - no post
    - fan running at 100%
    - unable to enter bios
    - on powerup with pinhole method the led's of the power button+esc key+caps key lights up green for a brief moment
    I've tried:
    - holding power button >30s while unplugged from ac+unplugged battery+unplugged cmos battery
    - above with pin hole method >10s
    Was willing to try:
    - obtaining bios .bin file from lenovo, finding out only a .exe file is available. So no point trying to flash bios with recovery, If this laptop even has such a hardware function build in. Did it before on a older amd based laptop by inserting a fat formatted usb stick with the bios file named accordingly and holding a combination of keys to start recovery process.
    - read the required guides on this site to find out there are no linux instructions for extracting .exe file content (or I missed it somehow). Will look into it some more.
    Unable to try:
    - reading eeprom since I have no programmer hardware. The affordable one isn't recommended according to the guide.
    Additional info:
    Serialnumber: MP1YLMQF. MTM: 20VE0049MH. MO: MPNXB1222034. On the motherboard I've found a sticker that says 8S5B21B33034C1KS12T00LB, PN: 5B21B33034 21-02-27 lenovo. The motherboard has two 8 pin IC's with the following printed on them: winbond 25Q90DVN1G, 24256E S0O065 (or is it S00065?).
    Requesting:
    Instructions on how to unbrick the ThinkBook 15 G2 ITL which has probably a faulty bios. This is the i7 version (don't know how much ram is soldered onto it) but it would be nice if it works again.
    Any help will be very much appreciated!
    Kind regards,
    MJ
  • hoaca388
    Badcaps
    • Jan 2022
    • 12490
    Originally posted by Magician1981
    Greetings,
    Where's your dump ?
    • shiyab
      • Sep 2023
      • 1747
      • india
      Greetings,
      TRY 8MB 16 MB BOTH R FLASH
      • Magician1981
        • Sep 2024
        • 16
        • netherlands
        Originally posted by hoaca388
        Where's your dump ?
        Unable to try:
        Looking on amazon as we speak for a ch341a with clip that is 3.3V capable. It is worth spending 10 euro's for a possible working laptop. Any brands I should stay away from?
        • Magician1981
          • Sep 2024
          • 16
          • netherlands
          May I inquire where/how you obtained this bios?
          • shiyab
            • Sep 2023
            • 1747
            • india
            HIS NEW BIOS
            • Magician1981
              • Sep 2024
              • 16
              • netherlands
              I've used asprogrammer to read the winbond chip twice and they are almost empty by the looks of it? There was no 25Q80DVN1G option only 25Q80DV. I made a mistake in my original post, needs to be 25Q80DVN1G instead of 25Q90DVN1G. Unfortunately I was not able to read the 24256E. Tried every possible position and _24Cxxx option from the menu. Verify IC> IC is not responding message. What am I doing wrong? Any help would mean a lot.
              Kind regards
                • 22396
                Kind regards
                None of those are the bios chip. Don`t erase them, leave them alone. I think your motherboard is a compal LA-K052P , you can use the LA-K051P schematic and boardview to help you locate the bios chips https://www.badcaps.net/forum/troubl...matic?t=114848
                • Magician1981
                  • Sep 2024
                  • 16
                  • netherlands
                  I has to be W25Q80EWZPIG_WSON8_6X5 then (UV21). It's on the other side. Can anyone confirm?
                  Update:
                  According to other post it is not. And having looked at the board more closely mine has several differences compared to LA-K051P.
                  • Magician1981
                    • Sep 2024
                    • 16
                    • netherlands
                    Found the ic's underneath the tape/heatpipe. Will upload backups soon.
                    • Magician1981
                      • Sep 2024
                      • 16
                      • netherlands
                      Trying with w25q128fv id. Seems w25q64fv does read something from the other chip. Found that suggestion on the winraid level1techs forum.
                      Update.
                      No go on the 128ahig. Used neoprogrammer and asprogrammer. Since this laptop came from a previous owner I'm guessing somebody messed with it. Here is the dump from the qh64ahig, verfied the md5.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12490
                        Update.
                        All you need is in # 3.
                        • Magician1981
                          • Sep 2024
                          • 16
                          • netherlands
                          I am looking for a version of NeoProgrammer, 2.1.0.19
                          According to info on winraid level1techs forum it is the only version that works good with the xm25qh128ahig when detecting/read/write.
                          Is it a good idea to expand this forum with a download section?
                          Kind regards
                            • 22396
                            Kind regards
                            Thread merged. NeoProgrammer 2.2.0.10 https://www.badcaps.net/forum/troubl...09#post1835409
                            Version 2.2.0.10 works ok, but if you want to try version 2.1.0.19 i`ve attached it.
                            • Magician1981
                              • Sep 2024
                              • 16
                              • netherlands
                              I had no luck with 2.2.0.10. Will give it a try tomorrow.
                              • Magician1981
                                • Sep 2024
                                • 16
                                • netherlands
                                Still no luck, the chip is dead I guess. Thanx anyway
                                  • 22396
                                  Is the type of bios chip SOP8 or WSON8 ,and what type of clip do you have, SOP or WSON
                                  • Magician1981
                                    • Sep 2024
                                    • 16
                                    • netherlands
                                    Sop and sop. Other ic "64" reads fine. Yesterday I was able to read the "128" a couple of times but every bin file had a different checksum. Today it won't read at all making me believe it has really died now.
                                    • huss584
                                      Hussein
                                      • Apr 2020
                                      • 234
                                      • Palestine
                                      Hello Everyone can any Professional help me to clean BIOS file During update I remove Battery
                                      Attach original file
                                      MP25D3HH
                                      • huss584
                                        Hussein
                                        • Apr 2020
                                        • 234
                                        • Palestine
                                        MP25D3HH
                                        Need Help Please any Update ?
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
                                        • Fr33man
                                          BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                                          by Fr33man
                                          I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                                          *Novo button power on
                                          *Disconnected internal battery...
                                          09-23-2024, 01:16 PM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • pcwhiz24
                                          Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                          by pcwhiz24
                                          Model: Lenovo IdeaPad 3 14ADA05 81W0
                                          S/N: PF2BZS7D
                                          I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                          I already have a CH341A programmer...
                                          04-07-2025, 07:10 PM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
