BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
  • Fr33man
    • Sep 2024
    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
    *Novo button power on
    *Disconnected internal battery & Cmos battery, pressed power button for 60 seconds
    *Removed & reseated SSD and RAM Sticks (cleaned), pressed power button for 60 seconds
    None of these have fixed the semi-bricked Bios, and so requesting the proper Bios file from this forum seems to be my last, best hope. Here's my specifications and the old bios is attached below,
    Model Name: IdeaPad 3-14ALC6
    Machine Type: 82KT
    CPU: Ryzen 5700U
    Serial Number: PF4CD0SF
    Machine Model: 82KT00YSAU
    Mother Board: BDPLANAR MBL82KTWINR75700UUMA_4G RPMC (Part No 5B21B85211)
    Thanks in advance, any help or information will be much appreciated...
    • 23693
    Do you have a bios programmer ?
    • Fr33man
      • Sep 2024
      No, I've checked out some YouTube videos on how to program bios chips with a CH341A but I've basically been running with the assumption that this won't be necessary with a semi-bricked bios? Is this a false assumption or can a USM flash drive with the proper Bios file do the job here?
      • ricky arana
        • Apr 2025
        • philiphines
        [QUOTE=Fr33man;n3467135]Hello everyone,
        Machine Type: 82KT
        CPU: Ryzen 5700U
        TR THIS 1
        • peste
          • 15083
          • ROMANIA
          [QUOTE=ricky arana;n3735122]
          Machine Type: 82KT
          CPU: Ryzen 5700U
          TR THIS 1
          you have everything you need at post #52...
          https://www.badcaps.net/forum/troubl...bios-plz/page3
          If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
          It only takes 1 minute:
          https://www.badcaps.net/settings/subscriptions
          • nixname
            • Jan 2026
            • greece
            Hello i ve got an ideapad 3 14alc06 that bricked after bios update. when i power it up all the buttons light for 5 secs and then only the power button. What i have to do guys? i Cant remember the last bios that it hass..
            • peste
              • 15083
              • ROMANIA
              ideapad 3 14alc06 or ideapad 3 14alc6???
              post S/N, full name and model, motherboard model, TYPE,etc.
              post the contents of the bios chip even if it is corrupted..
              The bios chip must be unsoldered from the board before writing or reading..
              do not use the clip, you may have errors..if you do not have anything to unsolder it with,
              solder wires between the programmer and the bios chip..
              you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
              • nixname
                • Jan 2026
                • greece
                Ideapad 3 14ALC6
                MO: PF9XB1C13105
                MTM: 82KT005NGM
                S/N PF3AGX7W
                all i know right now..
                • Deniz
                  IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
                  by Deniz
                  Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
                  I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
                  I had the BIOS cleaned, but the issue was not resolved and there was still no image.
                  Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
                  After that, I tried to update the...
                  01-27-2026, 06:56 AM
                • pcwhiz24
                  Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                  by pcwhiz24
                  Model: Lenovo IdeaPad 3 14ADA05 81W0
                  S/N: PF2BZS7D
                  I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                  I already have a CH341A programmer...
                  04-07-2025, 07:10 PM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • carabas20
                  BIOS bin file for Lenovo Ideapad 3 17ADA6 + 3 15ADA6
                  by carabas20
                  Hello i need BIOS bin file for Lenovo Ideapad 3 17ADA6 S/N PF3AALFM.
                  I have updated my bios from the official website , and after the laptop restarts it went to black screen and now i can not do anything. I have been trying to flash the bios with CH341A but from the office website i can see only the CAP file. I have need trying to modify the cap file following the guides and video from the forum but no luck.
                  If anyone has a dump of original bios for this model will be great or clean the faulty bios for me , i have attached my backup bios...
                  06-01-2023, 01:19 PM
                • m1ch43lzm
                  by m1ch43lzm
                  Hi everyone
                  09-06-2025, 05:47 PM
