Hp Elitebook 860 G10 Password Lock
    Originally posted by aabron View Post
    Hello, can some please explain what is the best way to read and write ec flash on elitebook 860 G10. I found the flash but there are a lot of small smd components very near. Is it safe to use kapton tape and hot air? Is it possible to use a wson8 8x6 clip and T48 to read and write it in circuit without corruption? I need to unlock bios. It is the last version and ec detects any change in bios and rewrites bios.
    here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
      Hi need Bios patch for HP 860 G10 can someone support please?
      ProdID: 975R8EC#ABD
      SN#: 5CG41733TC
      Thanks!
        ProdID: 975R8EC#ABD
        SN#: 5CG41733TC
        Thanks!
        what problem? bios locked?
          Yes
            SMDFlea commented
            Editing a comment
            Thread merged.
          ProdID: 975R8EC#ABD
          SN#: 5CG41733TC
          Thanks!
          hi try
            Hi, can someone help with BIOS password please?
            HP EliteBook 860 G10
            SN# 5CG42113KC
            ProdID 87B58EC#ABD
            backup bios attached
              I noticed there's a lot of unlock request for this model HP EliteBook 860 G10
              The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both!
              first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
              use BCU and put your original DMI.
              frequently asked questions:
              can i use this to my HP EliteBook 860 G10 - Yes
              Mod Edit: BID V70
                Hello all;
                HP EliteBook 860 G10 Notebook PC
                Prod ID 6V8X5AV
                Serial_5CG4175B2R
                Can someone please remove the password from the above bios manually? i have to patch with HP unlocker but doesnt work...
                Thank you in advance.
                  Originally posted by parisrenaud View Post
                  Hello all;
                  Prod ID 6V8X5AV
                  Serial_5CG4175B2R
                  Read the post above yours, flash those bios.
                    Hello all;
                    Prod ID 6V8X5AV
                    Serial_5CG4175B2R
                    hi try flash both ic and feedback
