Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Hp Elitebook 860 G10 Password Lock
  • shiyab
    replied
    Originally posted by harounHD
    need bios unlock for hp 860 g10
    sn : 5CG4165V9X
    hi try flash both
    Premium supporters get full download access and other benefits.
  • harounHD
    replied
    sn : 5CG4165V9X
  • gerlach
    replied
    Originally posted by SMDFlea
    Your BID is V70 ,read previous posts and you will find a way to unlock it .
    Thank you. You're right. Done. Thank you.
    replied
    Originally posted by gerlach
    Hello. Can someone help me unlock my BIOS? Thank you.
    HP EliteBook 860 G10
    SN# 5CG4323F3Y
    ProdID 6V8U8AV
    backup bios attached
  • gerlach
    replied
    SN# 5CG4323F3Y
    ProdID 6V8U8AV
    backup bios attached​
  • jotati7062
    replied
    Originally posted by jotati7062
    I end up using windows uuid for SMBIOS without the "-" and it worked, new issue, hp 860 G10 fingerprint scanner shows issue with device/driver after bios flash from post #27, i redid windows , drivers from hp site , did whole hp recovery image thing, no luck, im sure cable for fingerprint plugged and it was working 100% before the bios flash, possible bios chip has unique data about biometric fingerprint scanner? and any fix for that?
    @hoaca388
    SMDFlea
    Fixed , i had to enable Secure boot and it worked !
  • jotati7062
    replied
    Hello boss, I did flash the 2 files & bios works now, I did enter all DMI info, do i need to enter SMBIOS UUID ? its asking for it in bios settings
    Thank U
    @hoaca388
    SMDFlea
  • jotati7062
    replied
    Search for the text V70
    Thank U
  • jotati7062
    replied
    Thank u, i will flash both main bios & EC chip with previous post. and report back if all good
    replied
    Hi, how do I check BID v#
    I looked over hex editor but could not find it easy?
  • jotati7062
    replied
    Type the laptop serial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    Check your bios with a hex editor to see if the BID is V70 ,if it is you can use the bios posted by rex98 further up https://www.badcaps.net/forum/troubl...15#post3585615
    replied
    HP 860 G10 LOCKED
    Hello guys, I saw your posts of "hoaca388" on this fourm helping others which is very nice of him,
    i do have an HP 860 G10 LOCKED, i looked at the bytes he change after an unlock and applied the same on my bios file but i get error that "bios was recovered from EC chip due to data mismatch, do you guys think you can help? if so here is my main bios backup, if i have to backup EC chip, i will, Thank you so much
  • jotati7062
    replied
    HP 860 G10 LOCKED
  • kutsuy
    replied
    Originally posted by lapfix
    Rex file
    thanks!
  • lapfix
    replied
    Originally posted by kutsuy
    Hi,post this file again please,fail to download
    Rex file
  • kutsuy
    replied
    Originally posted by rex98
    I noticed there's a lot of unlock request for this model HP EliteBook 860 G10
    The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both!
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU and put your original DMI.
    frequently asked questions:
    can i use this to my HP EliteBook 860 G10 - Yes
    Mod Edit: BID V70
  • shiyab
    replied
    Originally posted by parisrenaud
    Hello all;
    HP EliteBook 860 G10 Notebook PC
    Prod ID 6V8X5AV
    Serial_5CG4175B2R
    Can someone please remove the password from the above bios manually? i have to patch with HP unlocker but doesnt work...
    Thank you in advance.​
    hi try flash both ic and feedback
    replied
    Hello all;
    Prod ID 6V8X5AV
    Serial_5CG4175B2R
    Read the post above yours, flash those bios.
  • parisrenaud
    replied
    Hello all;
    Prod ID 6V8X5AV
    Serial_5CG4175B2R
  • rex98
    replied
    Mod Edit: BID V70
  • ShadeRunner
    [REQUEST] BIOS Password Reset - HP EliteBook 830 G6 - Halt Code: qeh11u1kst
    by ShadeRunner
    I’m a student currently locked out of the BIOS on my HP EliteBook 830 G6. I bought the laptop second-hand, and the previous owner didn't provide the password. I really need access to the BIOS to change storage settings and boot orders for my studies.
    System Details:
    • Model: HP EliteBook 830 G6
    • Processor: Intel Core i5 (8th Gen)
    • Serial Number: 5CG0080LKD
    • Halt Code (from 3rd fail): qeh11u1kst
    I'm hoping someone here can help me generate an SMC.bin file or provide a master password that works for this generation. Any guidance on how to get back...
    03-17-2026, 10:49 AM
  • freeflight
    Need help removing Supervisor Password - HP EliteBook 865 G11
    by freeflight
    I need help to remove supervisor password.
    Model: HP EliteBook 865 G11
    Serial: 5CG5115HBH
    EC: NPCX499HA
    I already saved serial numbers using HP BCU.
    I will attach BIOS/EC dumps.
    Any help is appreciated. Thank you!
    04-16-2026, 01:42 PM
  • moshu
    HP EliteBook 755 G4 bios password locked
    by moshu
    Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
    I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
    Can you please help to remove the password?
    after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
    HP EliteBook 755 G4
    ProdID: W5Q98AV
    SN: 5CG7524BY4...
    02-01-2025, 06:59 AM
  • GoopyGoober
    Lenovo Thinkpad x2-1 Gen 9 BIOS supervisor password removal - Boot Lock
    by GoopyGoober
    I bought this laptop on vacation because the seller gave it to me for about 30 bucks converted USD. It's managed by some disbanded company but it worked fine. I was tinkering with it and secure wiped it because I wanted to reinstall windows 11 but the supervisor password locks everything and does not allow me to change anything in the bios menu/setup/etc. To get inside all I have to do is press enter when asked for the password, but other than that: can't change much. It sees me windows iso flash drive but won't allow me to change Secure Boot to let it boot.
    Is a supervisor password...
    06-27-2026, 09:44 PM
  • to5it0
    Title: HP EliteBook 840 G3 – Auto Power On Loop, Caps Lock LED Stays On – Need Power Rail Values Near CPU
    by to5it0
    Laptop: HP EliteBook 840 G3
    I’m troubleshooting a motherboard from an HP EliteBook 840 G3 and I’m facing a strange power issue. Problem Description
    • When I plug in the charger, the laptop automatically powers on (without pressing the power button).
    • The Caps Lock LED stays ON continuously.
    • The Power LED, Wi-Fi LED, and Mute LED also turn on.
    • After a few seconds, the laptop turns off, then automatically powers on again, creating a continuous power loop.
    Measurements
    I checked resistance to ground on the three inductors (coils) near...
    03-08-2026, 03:32 PM
