ASUS GL503VM-BI7N13 Bios password lock
  • birdboy385
    • Nov 2015
    • 145
    Hello All,
    I have the aforementioned laptop that I just purchased on ebay that was listed as having a BIOS password. Sure enough, on boot it requests a password. Here's the troubleshooting steps I've tried.
    1. just entering a blank password as I've seen where if it's an admin password instead of a user password, I can enter the BIOS as user and still enter Windows. I still receive Invalid Password, I'm assuming this means it's actually a user password or both user and admin password.
    2. I've removed both the main battery and CMOS battery, disconnected from power and held the power button down for about 1 minute. Hooking up only the power adapter, I turn the laptop back on, it goes through 2 reboots once it reaches the ASUS ROG logo, then on the 3rd boot, requests a password again.
    3. I tried pressing Alt+R since I read on some of these, it will generate a date code that can be decoded, this did not work and just entered an "r" in the password entry.
    I'm assuming at this point that the passwords are stored separately in an EEPROM chip or something. I don't have any tools at the moment for doing any kind of flashes or anything, but depending on the difficulty and cost, I wouldn't mind purchasing one to attempt a flash. I investigated simply replacing the main board, but those cost around 600$ from what I've seen and that would defeat the purpose since it would bring the cost of the laptop back to it's normal asking price (I paid 300$ for it).
    Does anyone have any ideas or suggestions for me to try to get this reset, other than return it to the seller lol?
  • birdboy385
    • Nov 2015
    • 145
    Re: ASUS GL503VM-BI7N13 Bios password lock
    Small Update.
    I've been doing some more research on the topic and I believe I've found my BIOS chip near the WIFI card. It's labeled mxic mx25l6473f.
    I've been reading that flashing can be possible with a CH341A programmer. This is pretty new territory for me so I'm not sure what I'm proposing is possible for this situation or if it would even work.
      • 22283
      Try to make a backup of the bios using Flash programming tool.
      Use this at the command line
      FPTW64.exe -D bios.bin
      If it makes a backup without any errors post it here and someone will have a look at it
      • birdboy385
        • Nov 2015
        • 145
        I'm assuming I'd need to obtain this CH341A programming tool since right now I don't really have any access to the laptop's bios? I think I get the gist of how the programmer works since I used a flasher to downgrade a PS3 a few years back and the concept seems similar.
          • 22283
          Try FPT first.It has an AMI bios,it might be possible to decode the password.If you can`t make a backup with FPT then yes you`ll need a programmer.The CH341A should do the job.If you buy the black PCB version its best to modify it before use,some of them have 5V on the data lines and need a wire soldering to make it 3.3V. The supplied software is shit,use NeoProgrammer,Colibri or ASProgrammer instead, theyre all posted here on the forum.
          • birdboy385
            • Nov 2015
            • 145
            Hmmm I guess I'm confused as to how I'd use it since I can't boot into windows or seemingly anything for that matter?
              • 22283
              I`m confused,at post #1 you said "I can enter the BIOS as user and still enter Windows"
              • birdboy385
                • Nov 2015
                • 145
                My apologies, my wording may have been confusing on my original post. When I mentioned where I've noticied people have been able to enter a blank password to get into Windows, that doesn't work for me.
                  • 22283
                  Its ok, just buy the programmer and post the backup here in a zip or rar.
                  CH341A volt mod videos
                  https://www.youtube.com/watch?v=-ln3VIZKKaE
                  https://www.youtube.com/watch?v=HwnzzF645hA
                  NeoProgrammer https://www.badcaps.net/forum/attach...7&d=1626459940
                  • birdboy385
                    • Nov 2015
                    • 145
                    Sounds like a plan. Thanks for that info. I'd hate to go into this immediately potentially frying my BIOS chip.
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                    • touftaf7301
                      ASUS TUF A17 – BIOS password removal request
                      by touftaf7301
                      I have an ASUS TUF A17 (model TUF707NV-HX088W, motherboard NJS / DA0NJSMBAF0 Rev F) that is locked by an UEFI BIOS password.
                      I have already checked the BIOS guides, methods, resources and tools section but could not find a working method for this specific model.
                      Details:
                      – Make/Model: ASUS TUF A17 TUF707NV-HX088W
                      – Motherboard: NJS / DA0NJSMBAF0 Rev F
                      – Serial number: S7NRCX05W03829E
                      – Issue: UEFI BIOS password locked (no access to BIOS setup or boot options)
                      – BIOS dump attached below (read with RT809F)...
                      11-07-2025, 02:15 PM
                    • grimacelord
                      by grimacelord
                      07-10-2025, 02:52 PM
                    • snpetit
                      Asus FA706IH Bios Password remove
                      by snpetit
                      i need some help :-/
                      i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                      Could you please remove all password related stuff from this bios. A hate Asus....
                      Thanks in advance!...
                      01-10-2025, 09:17 AM
                    • ArkzG
                      [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                      by ArkzG
                      Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                      What I currently have available:
                      - Model: FA506NF (2021)
                      - BIOS chip: GD25LQ16 (16Mbit/2MB)
                      - Tools: CH341A programmer ready to use
                      Does anyone have either a clean 2MB .bin dump of this model,...
                      09-26-2025, 09:34 PM
