Hp Elitebook 860 G10 Password Lock
  • peste
    • Dec 2016
    • 13625
    • ROMANIA
    Originally posted by aabron
    Hello, can some please explain what is the best way to read and write ec flash on elitebook 860 G10. I found the flash but there are a lot of small smd components very near. Is it safe to use kapton tape and hot air? Is it possible to use a wson8 8x6 clip and T48 to read and write it in circuit without corruption? I need to unlock bios. It is the last version and ec detects any change in bios and rewrites bios.
    here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    • racon55
      • Jan 2025
      • 3
      Hi need Bios patch for HP 860 G10 can someone support please?
      ProdID: 975R8EC#ABD
      SN#: 5CG41733TC
      Thanks!
      • alfredposadas09
        • Aug 2020
        • 342
        • Philippines
        ProdID: 975R8EC#ABD
        SN#: 5CG41733TC
        Thanks!
        what problem? bios locked?
        • racon55
          • Jan 2025
          • 3
          Yes
            SMDFlea commented
            Editing a comment
            Thread merged.
        • shiyab
          • Sep 2023
          • 1611
          • india
          ProdID: 975R8EC#ABD
          SN#: 5CG41733TC
          Thanks!
          hi try
          • Boddy
            • Feb 2025
            • Wonderland
            #26
            Hi, can someone help with BIOS password please?
            HP EliteBook 860 G10
            SN# 5CG42113KC
            ProdID 87B58EC#ABD​
            backup bios attached
            • rex98
              • Feb 2023
              • 1293
              • Mandaue CEBU, Philippines
              #27
              I noticed there's a lot of unlock request for this model HP EliteBook 860 G10
              The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both!
              first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
              use BCU and put your original DMI.
              frequently asked questions:
              can i use this to my HP EliteBook 860 G10 - Yes
              Mod Edit: BID V70
              • parisrenaud
                • Mar 2017
                • 4
                • France
                #28
                Hello all;
                HP EliteBook 860 G10 Notebook PC
                Prod ID 6V8X5AV
                Serial_5CG4175B2R
                Can someone please remove the password from the above bios manually? i have to patch with HP unlocker but doesnt work...
                Thank you in advance.​
                  • 21932
                  Originally posted by parisrenaud
                  Hello all;
                  Prod ID 6V8X5AV
                  Serial_5CG4175B2R
                  Read the post above yours, flash those bios.
                  • shiyab
                    • Sep 2023
                    • 1611
                    • india
                    #30
                    Hello all;
                    Prod ID 6V8X5AV
                    Serial_5CG4175B2R
                    hi try flash both ic and feedback
                    • kutsuy
                      • Dec 2022
                      • 13
                      • ukraine
                      #31
                      Mod Edit: BID V70
                      Hi,post this file again please,fail to download
                      • lapfix
                        • Mar 2020
                        • 2764
                        • my workshop
                        #32
                        Rex file
                        • kutsuy
                          • Dec 2022
                          • 13
                          • ukraine
                          #33
                          Originally posted by lapfix
                          Rex file
                          thanks!
                          • jotati7062
                            • Jan 2024
                            • 34
                            • SA
                            #34
                            HP 860 G10 LOCKED
                            Hello guys, I saw your posts of "hoaca388" on this fourm helping others which is very nice of him,
                            i do have an HP 860 G10 LOCKED, i looked at the bytes he change after an unlock and applied the same on my bios file but i get error that "bios was recovered from EC chip due to data mismatch, do you guys think you can help? if so here is my main bios backup, if i have to backup EC chip, i will, Thank you so much
                              • 21932
                              Originally posted by jotati7062
                              HP 860 G10 LOCKED
                              Type the laptop serial number, full name and model, motherboard model, etc.
                              read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                              Check your bios with a hex editor to see if the BID is V70 ,if it is you can use the bios posted by rex98 further up https://www.badcaps.net/forum/troubl...15#post3585615
                              • jotati7062
                                • Jan 2024
                                • 34
                                • SA
                                #36
                                Hi, how do I check BID v#
                                I looked over hex editor but could not find it easy?
                                  • 21932
                                  Search for the text V70
                                  • jotati7062
                                    • Jan 2024
                                    • 34
                                    • SA
                                    #38
                                    Thank u, i will flash both main bios & EC chip with previous post. and report back if all good
                                    • jotati7062
                                      • Jan 2024
                                      • 34
                                      • SA
                                      #39
                                      Hello boss, I did flash the 2 files & bios works now, I did enter all DMI info, do i need to enter SMBIOS UUID ? its asking for it in bios settings
                                      Thank U
                                      • jotati7062
                                        • Jan 2024
                                        • 34
                                        • SA
                                        #40
                                        Thank U
                                        I end up using windows uuid for SMBIOS without the "-" and it worked, new issue, hp 860 G10 fingerprint scanner shows issue with device/driver after bios flash from post #27, i redid windows , drivers from hp site , did whole hp recovery image thing, no luck, im sure cable for fingerprint plugged and it was working 100% before the bios flash, possible bios chip has unique data about biometric fingerprint scanner? and any fix for that?
                                        @hoaca388
                                        SMDFlea
                                        • moshu
                                          HP EliteBook 755 G4 bios password locked
                                          by moshu
                                          Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
                                          I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
                                          Can you please help to remove the password?
                                          after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
                                          HP EliteBook 755 G4
                                          ProdID: W5Q98AV
                                          SN: 5CG7524BY4...
                                          02-01-2025, 06:59 AM
                                        • Kiwi Viking
                                          HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
                                          by Kiwi Viking
                                          HP Elitebook 855 G8
                                          Product ID:4X5S2PA#ABG
                                          Motherboard M53301-601.
                                          Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
                                          When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
                                          03-01-2025, 01:05 AM
                                        • birdboy385
                                          ASUS GL503VM-BI7N13 Bios password lock
                                          by birdboy385
                                          Hello All,
                                          I have the aforementioned laptop that I just purchased on ebay that was listed as having a BIOS password. Sure enough, on boot it requests a password. Here's the troubleshooting steps I've tried.
                                          1. just entering a blank password as I've seen where if it's an admin password instead of a user password, I can enter the BIOS as user and still enter Windows. I still receive Invalid Password, I'm assuming this means it's actually a user password or both user and admin password.
                                          2. I've removed both the main battery and CMOS battery, disconnected...
                                          12-04-2021, 10:36 AM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
                                          HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:20 AM
