Hp Elitebook 860 G10 Password Lock
  • Satus
    • May 2016
    • 20
    • South Africa
    Good day everyone . Please can someone assist me in Unlocking this files below, i try using the method of unlocking HP Elitebook 840 its not working on this Model Please kindly assist me to unlock this file
    Here is the Info of the Laptop
    Hp EliteBook 860 G10
    S/N 5CG35067WW
    Backup Main and EC Files are Attached
  • hoaca388
    Badcaps
    • Jan 2022
    • 12330
    S/N 5CG35067WW
    HP EliteBook 860 16 inch G10 Notebook PC
    CT Number_6MBNK0FTZIPKRJ
    Serial_5CG35067WW
    Sku_976J3EC#ACQ
    Fearture byte_476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUcAeMfPguhKhkjhk8mEmVn7nVngpDpVpnpqprqMqkqz.4y
    Build Id_23WWWGBZ602#SACQ#DACQ
    • Satus
      • May 2016
      • 20
      • South Africa
      hoaca388 it worked Thank you so much
      • atell55
        • Oct 2024
        • Ecuador
        Hello Everyone I have similar laptop 860 G10 with bios administrator password issue..I need to remove it..is the file that you share would work in my laptop or do i summit my bios file..
        Thanks in advance..
          SMDFlea commented
          Editing a comment
          Submit your bios backups and laptop serial number.
      • abuge
        • Oct 2022
        • 69
        hello sir can you unlock bios password from my laptop 860 g10
        serial : 5CG3350GH0
        backup bios attach
        • m.sabry2110
          • Oct 2017
          • 134
          • egypt
          serial : 5CG3350GH0
          backup bios attach
          try
          • abuge
            • Oct 2022
            • 69
            Originally posted by m.sabry2110
            try
            thank you sir but not worked after recover its ask password ... any other friend can check my bios
            • abuge
              • Oct 2022
              • 69
              serial : 5CG3350GH0
              backup bios attach
              Hello sir hoaca can you unlock my bios please
              • shiyab
                • Sep 2023
                • 1609
                • india
                serial : 5CG3350GH0
                backup bios attach
                post both file
                • abuge
                  • Oct 2022
                  • 69
                  Originally posted by shiyab
                  post both file
                  here is both files
                  • qayyum786
                    • Aug 2018
                    • 1959
                    • INDIA
                    here is both files
                    At 1st boot press F10 and RESET BIOS to factory defaults
                    • abuge
                      • Oct 2022
                      • 69
                      Not worked again password after three time restart ..
                      • abuge
                        • Oct 2022
                        • 69
                        Serial_5CG35067WW
                        Sku_976J3EC#ACQ
                        hoaca388 Sir can you please check my file and unlock it
                        • qayyum786
                          • Aug 2018
                          • 1959
                          • INDIA
                          Try again
                          flash both
                          • Dennis Gessner
                            • Dec 2024
                            • Deutschland
                            serial : 5CG3255C4F
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12330
                              CT Number_6MBNK0FTZIB72Z
                              Serial_5CG3350GH0
                              Sku_81A76EA#ABF
                              Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfPguhKhkjhk8mEn7nVngpDpTpnpqprqMqkqz.nD
                              Build Id_23WWWGBZ601#SABF#DABF
                              • aabron
                                • Jul 2014
                                • Croatia
                                Hello Sir. Can you please unlock bios password for my 860 g10. Serial 5CG3301FMG. Do I need ec.bin? Do i need to desolder it? Can I read it with CH341a 3.3 mod?
                                • shiyab
                                  • Sep 2023
                                  • 1609
                                  • india
                                  hi try
                                  • aabron
                                    • Jul 2014
                                    • Croatia
                                    hi try
                                    EC rewrites the bios because of the keys and it asks password again.
                                    • aabron
                                      • Jul 2014
                                      • Croatia
                                      Hello, can some please explain what is the best way to read and write ec flash on elitebook 860 G10. I found the flash but there are a lot of small smd components very near. Is it safe to use kapton tape and hot air? Is it possible to use a wson8 8x6 clip and T48 to read and write it in circuit without corruption? I need to unlock bios. It is the last version and ec detects any change in bios and rewrites bios.
                                      • moshu
                                        HP EliteBook 755 G4 bios password locked
                                        by moshu
                                        Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
                                        I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
                                        Can you please help to remove the password?
                                        after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
                                        HP EliteBook 755 G4
                                        ProdID: W5Q98AV
                                        SN: 5CG7524BY4...
                                        02-01-2025, 06:59 AM
                                      • Kiwi Viking
                                        HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
                                        by Kiwi Viking
                                        HP Elitebook 855 G8
                                        Product ID:4X5S2PA#ABG
                                        Motherboard M53301-601.
                                        Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
                                        When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
                                        03-01-2025, 01:05 AM
                                      • birdboy385
                                        ASUS GL503VM-BI7N13 Bios password lock
                                        by birdboy385
                                        Hello All,
                                        I have the aforementioned laptop that I just purchased on ebay that was listed as having a BIOS password. Sure enough, on boot it requests a password. Here's the troubleshooting steps I've tried.
                                        1. just entering a blank password as I've seen where if it's an admin password instead of a user password, I can enter the BIOS as user and still enter Windows. I still receive Invalid Password, I'm assuming this means it's actually a user password or both user and admin password.
                                        2. I've removed both the main battery and CMOS battery, disconnected...
                                        12-04-2021, 10:36 AM
                                      • Nopslide
                                        HP Omen 15-dh0052nf power-on & bios password
                                        by Nopslide
                                        Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                        My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                        Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                        04-01-2024, 04:27 PM
                                        HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-07-2024, 05:20 AM
