Asus M513UA-BB71-CB GD25LQ128C bios issues
  • ub6ib969
    • Jul 2010
    • 198
    Have a Asus M513UA-BB71-CB that powers on however does not post. Fan spins and flashing power light every 5 seconds after windows update. I have attached serial number and bios dump. thank you in advance.
    s/n: MAN0CV13Z069421
    motherboard: X513UA R2.2
    bios: GD25LQ128C
  • volinakis
    • Jan 2021
    • 2733
    • N/A
    model: MAN0CV13Z069421
    bios: GD25LQ128C
    try
    • ub6ib969
      • Jul 2010
      • 198
      thank you but didn't work. Fan spin, unit powers on however does not post.
      • volinakis
        • Jan 2021
        • 2733
        • N/A
        try an older version
        • ub6ib969
          • Jul 2010
          • 198
          got the same result. I think the onboard memory might be an issue. can I request that onboard ram can be disabled from the bios?
          fan spins, cpu gets hot but no image. Even removed the bios and powered on the unit. boots up acts the same with the bios Ic on board and removed.
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • lrouw84
            by lrouw84
            Hi there,
            01-28-2023, 01:31 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • oragano
            ASUS ex-b250-V7 motherboard bios corrupted - by me
            by oragano
            hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
            So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
            i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
            10-17-2024, 02:53 AM
