Asus M513UA-BB71-CB GD25LQ128C bios issues
  • ub6ib969
    • Jul 2010
    • 201
    Have a Asus M513UA-BB71-CB that powers on however does not post. Fan spins and flashing power light every 5 seconds after windows update. I have attached serial number and bios dump. thank you in advance.
    s/n: MAN0CV13Z069421
    motherboard: X513UA R2.2
    bios: GD25LQ128C
  • volinakis
    • Jan 2021
    • 2874
    • N/A
    model: MAN0CV13Z069421
    bios: GD25LQ128C
    try
    • ub6ib969
      • Jul 2010
      • 201
      thank you but didn't work. Fan spin, unit powers on however does not post.
      • volinakis
        • Jan 2021
        • 2874
        • N/A
        try an older version
        • ub6ib969
          • Jul 2010
          • 201
          got the same result. I think the onboard memory might be an issue. can I request that onboard ram can be disabled from the bios?
          fan spins, cpu gets hot but no image. Even removed the bios and powered on the unit. boots up acts the same with the bios Ic on board and removed.
          • MOMO15
            • Jun 2023
            • 7
            • france
            hello i need asus m515ua bios .bin thank you
          • shiyab
            • Sep 2023
            • 1626
            • india
            post backup bios and snid
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • lrouw84
              Asus vivobook s510ua bios changed to x510un
              by lrouw84
              Hi there,
              I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
              I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
              01-28-2023, 01:31 PM
            • ferah831208
              help with bios decompose for Asus s5506ma
              by ferah831208
              I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
              08-24-2025, 05:35 PM
            • Sathsul
              Dell Latitude 5431 issues with dumping bios
              by Sathsul
              So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
              The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
              However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
              10-28-2025, 07:49 AM
