Add chip support to EZP2019, EZP2019+, EZP2020, EZP2023, EZP2025, MinPro Programmers
  • rockman97
    • Aug 2025
    • 10
    • Hungary
    Originally posted by m1ch43lzm
    rockman97
    I'll attach the EZP2019+ software for you, downloaded from site linked at 1st post, I don't own this programmer
    The W25Q256FW is listed, it should be compatible, you have to use 1.8V adapter
    I'm really noob for ad this type of chip can i get a help please how can i do it i really want fix this motherboard for myself but i don't really understand what i need to do.
    I had this Windbond 25Q256JWEQ which chip is similar to choose this?
    I tried use chatgpt what i need to add but not really understand how work i tried select the FW version but sadly it 0 when i want read the chip.
    Thank you for the files!
    • Derach
      • Jun 2017
      • 12
      • burkina faso
      thanks for sharing
      • shaddy254
        • Feb 2021
        • 33
        • kenya
        Originally posted by ToNe 36
        here you can find updated version fixed by the developer which he has sent me...no need for locale emulator
        works very well. Thanks for sharing.
        • rockman97
          • Aug 2025
          • 10
          • Hungary
          rockman97
          Thank you for the link maybe i noob but how can i use it i need overwrite databas file from here EZP2019+ database.rar if i does this the program not open and crash.
          If i select W25Q256FW 1.8V with the 1.8v adapter not recognize it. I tried select this
          • m1ch43lzm
            • Mar 2019
            • 731
            • Peru
            If you're using a clip, it may take few tries to align it properly, even if it looks right sometimes there's 1 or 2 pins that don't make proper contact, make sure you didn't connect the 1.8V adapter or the clip the wrong way, also try lowering the SPI clock speed to 3MHz or even 1.5MHz
            I don't own that programmer so I can't give advice how to use it, sorry, but check some YT videos, couldn't find videos in English for this programmer
            How to use 1.8v adapter (EZP2010, but it's similar)
            https://www.youtube.com/watch?v=eED9r9B89uM
            How to use EZP2019+
            https://www.youtube.com/watch?v=_7l9Ov3cUhY
            https://www.youtube.com/watch?v=ysvZjrYNIdw
            • Troystain
              Help EZP2023+ updated chip database for w25q256jveq?
              by Troystain
              Hello, anyone here have updated ezp2023+ chip database in .dat file format.
              I need to add w25q256jveq chip but I do not know what data should I type.
              I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
              The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
              11-25-2024, 12:53 AM
            • sume
              bios chip can not detected on ezp
              by sume
              I'm having trouble writing the BIOS to an mXIC MX77U25650F chip using both the EZP2019+ and EZP2023+ programmers. I have tried various connections, but I'm still encountering the same issue. The chip itself is kind of hard to solder. I am using SOP16/8-DIP8 REV4 Board Adapter because it is the only suitable one. How can i fix this issue. The motherboard it belong to is HE430HE530 NM-D481 Rev1.0. And the laptop is Lenovo thinkpad e15 gen3. I fixed many bios chips, but this one is very different.
              05-03-2025, 04:34 AM
            • ToNe 36
              EZP2025 Working english program
              by ToNe 36
              Hello from Romania here I present you the working EZP2025 without using locale editor sent to me by the developer.
              It works without having to tweak it with locale emulator..
              I sent mails to the developer and he was kind enough to send me the fixed version which is not having the richedit error....
              Please save it and share it on other forums as well as the chinese man said he can not upload it on his website....strange....
              EZP 2025 works only with this version so it will not work with older versions..........
              06-21-2025, 01:32 PM
            • pengamat_hebat
              Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
              by pengamat_hebat
              I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
              Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
              However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
              I also tried applying 3.3V to pin 3, but it still didn't work.
              I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
              03-25-2025, 04:13 AM
            • Souricier
              Flashing HP Elitebook x360 1030 g2 with EZP2023+
              by Souricier
              The model is HP Elitebook x360 1030 g2
              S/N is 5CG7342PY8
              6043B0211511 Rev A01 could be the mothercard model
              I have succeeded removing the Winband W25Q128JV from the MotherCard => should I also remove W25Q64JV ?
              When I am reading the 128 with EZP2023+ it's telling me it's ATMEL 93_EEPROM AT93C46@16 ...
              Is this program reader able to detect this chip ?
              I have used a adaptor from SOP8/16 to DIP8 (150m) : is that correct ?
              Thank you for your help
              08-08-2024, 12:11 PM
